[AG-TECH] vic works on command line but fails to be started via AG
Natalia Costas Lago
natalia at cesga.es
Wed Jun 22 01:29:35 CDT 2005
Have a look at the venue log, to check which kind of call the venue client
does to start vic and check errors.
----- Original Message -----
To: <ag-tech at mcs.anl.gov>
Sent: Wednesday, June 22, 2005 5:17 AM
Subject: Re: [AG-TECH] vic works on command line but fails to be started via
AG
> Hi All:
> vic fails to come up on a Windows XP laptop. However when I
> start vic on the command line it shows the video streams. Other
> than a re-install, any suggestions?
> regards,
> west
> On 6/21/05, west suhanic <west.suhanic at gmail.com> wrote:
>> Hi Thomas:
>> I checked the emerge log. I did not see any complaint about or even
>> mention of /etc/AccessGrid. I did not see mention of /etc . Also there
>> was no
>> ~/.AccessGrid created. I am open to any and all suggestions.
>> regards,
>> west
>> On 6/21/05, Thomas D. Uram <turam at mcs.anl.gov> wrote:
>> > The complaint is about /etc/AccessGrid/SharedApplications .
>> > I expect to see some failure in the emerge output regarding this and
>> > other directories.
>> > West: Do you see any failures regarding directories in
>> > /etc/AccessGrid? Do you see a
>> > complaint about configuration files (which reside in /etc)?
>> > Tom
>> > On 06/20/05 17:22, Douglas Kosovic wrote:
>> > > Hi West,
>> > >> File
>> > >> "/usr/lib/python2.3/site-packages/AccessGrid/Platform/unix/Config.py",
>> > >> line 100, in _Initialize
>> > >> self.GetSharedAppDir()
>> > >> File
>> > >> line 208, in GetSharedAppDir
>> > >> raise Exception, "AGTkConfig: app dir does not exist."
>> > >> Exception: AGTkConfig: app dir does not exist.
>> > >> Any suggestions?
>> > > I think it's complaining about either one of the following dirs:
>> > > ~/.AccessGrid/SharedApplications/
>> > > $AGTK_USER/SharedApplications/
>> > > The latter only if the AGTK_USER env variable is set.
>> > > Check the ownership and permissions of ~/.AccessGrid/ or just issue
>> > > something like:
>> > > mv ~/.AccessGrid ~/AccessGrid.bak
>> > > Cheers,
>> > > Doug
