[AG-TECH] Gentoo: agpm.py and VenueServer fail.
west suhanic
west.suhanic at gmail.com
Tue Jun 21 08:46:08 CDT 2005
Hi Thomas:
I checked the emerge log. I did not see any complaint about or even
mention of /etc/AccessGrid. I did not see mention of /etc . Also there
was no
~/.AccessGrid created. I am open to any and all suggestions.
regards,
west
On 6/21/05, Thomas D. Uram <turam at mcs.anl.gov> wrote:
> The complaint is about /etc/AccessGrid/SharedApplications .
> I expect to see some failure in the emerge output regarding this and other directories.
> West: Do you see any failures regarding directories in /etc/AccessGrid? Do you see a
> complaint about configuration files (which reside in /etc)?
> Tom
> On 06/20/05 17:22, Douglas Kosovic wrote:
> > Hi West,
> >> File
> >> "/usr/lib/python2.3/site-packages/AccessGrid/Platform/unix/Config.py",
> >> line 100, in _Initialize
> >> self.GetSharedAppDir()
> >> File
> >> line 208, in GetSharedAppDir
> >> raise Exception, "AGTkConfig: app dir does not exist."
> >> Exception: AGTkConfig: app dir does not exist.
> >> Any suggestions?
> > I think it's complaining about either one of the following dirs:
> > ~/.AccessGrid/SharedApplications/
> > $AGTK_USER/SharedApplications/
> > The latter only if the AGTK_USER env variable is set.
> > Check the ownership and permissions of ~/.AccessGrid/ or just issue
> > something like:
> > mv ~/.AccessGrid ~/AccessGrid.bak
> > Cheers,
> > Doug
