[AG-TECH] Gentoo: agpm.py and VenueServer fail.
Thomas D. Uram
turam at mcs.anl.gov
Mon Jun 20 23:48:43 CDT 2005
The complaint is about /etc/AccessGrid/SharedApplications .
I expect to see some failure in the emerge output regarding this and other directories.
West: Do you see any failures regarding directories in /etc/AccessGrid? Do you see a
complaint about configuration files (which reside in /etc)?
Tom
On 06/20/05 17:22, Douglas Kosovic wrote:
> Hi West,
>> File
>> "/usr/lib/python2.3/site-packages/AccessGrid/Platform/unix/Config.py",
>> line 100, in _Initialize
>> self.GetSharedAppDir()
>> File
>> line 208, in GetSharedAppDir
>> raise Exception, "AGTkConfig: app dir does not exist."
>> Exception: AGTkConfig: app dir does not exist.
>> Any suggestions?
> I think it's complaining about either one of the following dirs:
> ~/.AccessGrid/SharedApplications/
> $AGTK_USER/SharedApplications/
> The latter only if the AGTK_USER env variable is set.
> Check the ownership and permissions of ~/.AccessGrid/ or just issue
> something like:
> mv ~/.AccessGrid ~/AccessGrid.bak
> Cheers,
> Doug
