[AG-TECH] Osprey 440 Cards, Matrox QID Video Card, Recommended Soundcard
Nathan Gardiner
nathan.gardiner at canterbury.ac.nz
Mon Jun 20 15:27:27 CDT 2005
Thanks Derek / Peter for those comments. I'll be testing the Matrox QID
PCI-e Card in the next few days. I believe it is built for Low Profile
machines but comes with a bracket to fit ATX cases? We would be looking
at putting in an ATX case.
I have tried the Spectra8 Card and it works well under Windows. The only
problem however is under windows xp, every time I go into a room, 4
popups come up and I have to select each of the video sources. Not a big
problem but quite annoying. Is there a way around this? Can this be hard
coded into the Access Grid to automatically select each of the video
sources? I know that this problem doesn't happen under Linux.
Also Winnov Video Quattro Cards are a possiblilty. I have read in
earlier posts that quite a few people use this. Does it work well under
Windows XP?
Cheers,
Nathan
-----Original Message-----
Sent: Tuesday, 21 June 2005 1:28 a.m.
To: Peter DeSantis
Cc: Nathan Gardiner; ag-tech at mcs.anl.gov
Subject: Re: [AG-TECH] Osprey 440 Cards, Matrox QID Video Card,
While I've not used the 4-port Osprey, I have used a Spectra8
which has
4 bt878 chips on it. It works very well, just like 4 independent capture
cards except it's only taking up one slot. I don't know if the Osprey
has the same chips on it, I know the Osprey 100 we have uses the 878 so
I could *assume* that it does, but I don't know.
We have a Matrox QID AGP, but we run ours in 'stretched' 2x2
mode and have had no problems at all.
Derek
Peter DeSantis wrote:
> Matrox QID PCI-e Video Card - 4x DVI / VGA output graphics card We
> used this in an AG, only problem we had was that we could not get it
to work in the indepednent screen mode. The AG software would leave
screen corruption trails all over and eventually lock the system.
> In the stretch screen mode (where you have all screens same res, and
colour depth) it work fine, no problems that we could find, and good
performance in my opinion.
> Why it didnt work in the indepednat screen mode i dont know, my guess
is the driver was not mature enough, that may have changed by now, but i
could get no response from matrox (other than "we are not aware of any
problems with this product"). We didnt have another mainboard to test
it with, so the problems may have been compatability issues, but im
leaning to the driver issue myself. In the end we left it in the AG,
and will prob use it in others.
> Didnt know there was a 4 channel osprey, gonna check that one out
> myself
> Peter
> >> Hi all,
> >> Just wanting to know if anyone has experimented with or is
> currently using >> any of these two pieces of hardware under an
Access Grid session.
> >> Osprey 440 - 4 Port PCI video capture card (due to be
> commercially release >> shortly) >> Matrox QID PCI-e Video Card -
> 4x DVI / VGA output graphics card >> >> Also when testing AG 2.3
> with standard onboard motherboard soundcards on >> pc's, when we
> increased the audio quality on RAT using the Linear Codec >> up to
> 44khz that it would generally crash after around 5 minutes. I would
> >> say the obvious problem would be the onboard soundcards. Is there
> a >> recommended soundcard that can successfully maintain high audio
> streaming >> in AG 2.3? I was thinking of something like
Soundblaster Live or Audigy.
> >> Thanks so much for any input or suggestions.
> >> Kind regards,
> >> Nathan Gardiner
> >> Human Interface Technology Lab NZ (HIT Lab NZ) >> Room 110, Old
> Maths Building, University of Canterbury >> DDI: 364 3072, Cell: 021
> 163 2956, www.hitlabnz.org >>
Derek Piper - dcpiper at indiana.edu - (812) 856 0111 IRI 323, School of
Informatics Indiana University, Bloomington, Indiana
