[AG-TECH] Venue and Bridge Server specs
Todd Zimmerman
toddz at sfu.ca
Mon Jun 13 11:22:07 CDT 2005
Sorry - my bad.
Just been informed that the P3 is actually a dual processor also...
And should also noted that the P4 is a dual Xeon just for clarification.
Todd
Collaboration & Visualization Technician
WestGrid - www.westgrid.ca
IRMACS - www.irmacs.com
Ph. 604.268.6979
Todd Zimmerman - toddz at sfu.ca
Todd Zimmerman wrote:
> The P3 is a single, the P4 is a dual.
> Todd
> Natalia Costas Lago wrote:
>> Is it dual or single processor?
>> ----- Original Message ----- From: "Todd Zimmerman" <toddz at sfu.ca>
>> To: "Andrew Rowley" <Andrew.Rowley at manchester.ac.uk>
>> Cc: "'ag-tech'" <ag-tech at mcs.anl.gov>
>> Sent: Thursday, June 09, 2005 6:38 PM
>> Subject: Re: [AG-TECH] Venue and Bridge Server specs
>>> Agreed on the crashing. Our venueserver hasn't had any problems and
>>> it runs 24/7. It usually only needs to be restarted about once ever
>>> month or so...
>>> Concerning configuration and setup, our main venueserver runs on the
>>> same machine as one of our bridges, while a second machine serves
>>> mostly as a second bridge (geographically separated) but can serve as
>>> a backup venueserver in times of crisis.
>>> One machine is a P3 1Ghz, the other a P4 2.8Ghz, both with 2 GB of mem.
>>> Neither has had an issue with performance and we host some fairly
>>> large meetings occassionally...
>>> Todd
>>> Ph. 604.268.6979
>>> Derek Piper wrote:
>>>> Your VenueServer crashes a lot? hmm. I actually run ours on the
>>>> same machine that does our Audio and Video for the node we have
>>>> here. This was simple because when I was installing it last year, it
>>>> was deemed that that was 'the AccessGrid Linux machine'. Whether
>>>> that's smart or not, I don't know, but I've found it to be very
>>>> stable. It's a single P4/3Ghz with 1GB RAM. The machine was recently
>>>> reformatted and reinstalled (now Debian Sarge instead of RedHat 9)
>>>> because of a failing harddrive (Dell and their Maxtors ... sheesh).
>>>> The VenueServer had to be restarted occaisionally, but I'm thinking
>>>> it was a few months between intervals. We have a bridge server on a
>>>> different machine (another 3Ghz P4 that does web stuff), since
>>>> because of the audio and video VICs on the AV machine, they cannot
>>>> occupy the same machine.
>>>> Derek
>>>> Andrew Rowley wrote:
>>>>> Relating to this, I also wondered if people generally run their bridge
>>>>> server and venue server on the same of separate machines?
>>>>> We currently run ours on the same machine (a P4 1.7Ghz with 512MB
>>>>> RAM). The
>>>>> venueserver crashes fairly often, and I sometimes find that
>>>>> restarting the
>>>>> bridge server helps, so I assume the bridge server sometimes puts a
>>>>> lot of
>>>>> load on the server.
>>>>> Andrew :)
>>>>> Access Grid Support Centre,
>>>>> RSS Group,
>>>>> Manchester Computing,
>>>>> Kilburn Building,
>>>>> University of Manchester,
>>>>> Oxford Road,
>>>>> Manchester,
>>>>> M13 9PL,
>>>>> UK
>>>>> Tel: +44(0)161-275 0685
>>>>> Email: Andrew.Rowley at manchester.ac.uk
>>>>> ________________________________________
>>>>> From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov]
>>>>> On Behalf
>>>>> Of Natalia Costas Lago
>>>>> Sent: 09 June 2005 08:39
>>>>> To: ag-tech
>>>>> Subject: [AG-TECH] Venue and Bridge Server specs
>>>>> Dear all,
>>>>> Seeking for some information related to the hardware I need for
>>>>> our own
>>>>> venue/bridge server I found two threads with no answer to this
>>>>> question. It seems to me that the venue server doesnt need heavy
>>>>> resources, but I'm
>>>>> not so sure about the bridge server.
>>>>> I would really appreciate the sites that hold/organise very big
>>>>> meetings (as
>>>>> Argonne with SCGlobal for instance), and have much experience in these
>>>>> matters, give us some guidelines about the specs recommended (or the
>>>>> place/website where I could gather some information). Kind regards,
>>>>> Natalia.
>>>>> Natalia Costas Lago
>>>>> email: natalia at cesga.es
>>>>> Centro de Supercomputacion de Galicia (CESGA)
>>>>> Avenida de Vigo, s/n Campus Sur 15706 Santiago de Compostela - SPAIN
>>>>> Tel: +34 981 56 98 10 Fax: +34 981 59 46 16
>>>>> http://www.cesga.es/
