[AG-TECH] Venue and Bridge Server specs
Todd Zimmerman
toddz at sfu.ca
Fri Jun 10 18:11:02 CDT 2005
The P3 is a single, the P4 is a dual.
Todd
Natalia Costas Lago wrote:
> Is it dual or single processor?
> ----- Original Message ----- From: "Todd Zimmerman" <toddz at sfu.ca>
> To: "Andrew Rowley" <Andrew.Rowley at manchester.ac.uk>
> Cc: "'ag-tech'" <ag-tech at mcs.anl.gov>
> Sent: Thursday, June 09, 2005 6:38 PM
> Subject: Re: [AG-TECH] Venue and Bridge Server specs
>> Agreed on the crashing. Our venueserver hasn't had any problems and
>> it runs 24/7. It usually only needs to be restarted about once ever
>> month or so...
>> Concerning configuration and setup, our main venueserver runs on the
>> same machine as one of our bridges, while a second machine serves
>> mostly as a second bridge (geographically separated) but can serve as
>> a backup venueserver in times of crisis.
>> One machine is a P3 1Ghz, the other a P4 2.8Ghz, both with 2 GB of mem.
>> Neither has had an issue with performance and we host some fairly
>> large meetings occassionally...
>> Todd
>> Collaboration & Visualization Technician
>> WestGrid - www.westgrid.ca
>> IRMACS - www.irmacs.com
>> Ph. 604.268.6979
>> Todd Zimmerman - toddz at sfu.ca
>> Derek Piper wrote:
>>> Your VenueServer crashes a lot? hmm. I actually run ours on the
>>> same machine that does our Audio and Video for the node we have here.
>>> This was simple because when I was installing it last year, it was
>>> deemed that that was 'the AccessGrid Linux machine'. Whether that's
>>> smart or not, I don't know, but I've found it to be very stable. It's
>>> a single P4/3Ghz with 1GB RAM. The machine was recently reformatted
>>> and reinstalled (now Debian Sarge instead of RedHat 9) because of a
>>> failing harddrive (Dell and their Maxtors ... sheesh). The
>>> VenueServer had to be restarted occaisionally, but I'm thinking it
>>> was a few months between intervals. We have a bridge server on a
>>> different machine (another 3Ghz P4 that does web stuff), since
>>> because of the audio and video VICs on the AV machine, they cannot
>>> occupy the same machine.
>>> Derek
>>> Andrew Rowley wrote:
>>>> Relating to this, I also wondered if people generally run their bridge
>>>> server and venue server on the same of separate machines?
>>>> We currently run ours on the same machine (a P4 1.7Ghz with 512MB
>>>> RAM). The
>>>> venueserver crashes fairly often, and I sometimes find that
>>>> restarting the
>>>> bridge server helps, so I assume the bridge server sometimes puts a
>>>> lot of
>>>> load on the server.
>>>> Andrew :)
>>>> Access Grid Support Centre,
>>>> RSS Group,
>>>> Manchester Computing,
>>>> Kilburn Building,
>>>> University of Manchester,
>>>> Oxford Road,
>>>> Manchester,
>>>> M13 9PL,
>>>> UK
>>>> Tel: +44(0)161-275 0685
>>>> Email: Andrew.Rowley at manchester.ac.uk
>>>> ________________________________________
>>>> From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov]
>>>> On Behalf
>>>> Of Natalia Costas Lago
>>>> Sent: 09 June 2005 08:39
>>>> To: ag-tech
>>>> Subject: [AG-TECH] Venue and Bridge Server specs
>>>> Dear all,
>>>> Seeking for some information related to the hardware I need for our
>>>> own
>>>> venue/bridge server I found two threads with no answer to this
>>>> question. It seems to me that the venue server doesnt need heavy
>>>> resources, but I'm
>>>> not so sure about the bridge server.
>>>> I would really appreciate the sites that hold/organise very big
>>>> meetings (as
>>>> Argonne with SCGlobal for instance), and have much experience in these
>>>> matters, give us some guidelines about the specs recommended (or the
>>>> place/website where I could gather some information). Kind regards,
>>>> Natalia.
>>>> Natalia Costas Lago
>>>> email: natalia at cesga.es
>>>> Centro de Supercomputacion de Galicia (CESGA)
>>>> Avenida de Vigo, s/n Campus Sur 15706 Santiago de Compostela - SPAIN
>>>> Tel: +34 981 56 98 10 Fax: +34 981 59 46 16
>>>> http://www.cesga.es/
