[AG-TECH] Multi Display Cards Recommendation
Natalia Costas Lago
natalia at cesga.es
Mon Jun 13 02:20:28 CDT 2005
I've found this _very interesting_ (it seems to me at least) webpage and
website.
http://www.multiplemonitors.org/Pages%20-%20Hardware/Hardware%20-%20Multi%20head%20Video%20cards.html
Natalia
----- Original Message -----
From: "Peter DeSantis" <peter at jumbovision.com.au>
To: "Natalia Costas Lago" <natalia at cesga.es>; "Derek Piper"
<dcpiper at indiana.edu>; "Todd Zimmerman" <toddz at sfu.ca>
Cc: "'ag-tech'" <ag-tech at mcs.anl.gov>; "Westgrid-AGTECH"
<westgrid-agtech-l at majordomo.netera.ca>
Sent: Friday, June 10, 2005 9:38 AM
Subject: re[4]: [AG-TECH] Multi Display Cards Recommendation
> the matrox drivers have amatrox tool to switch between multiscreen and
> stretch mode.
> multiscreen = up to 4 vga screens, each screen can be set to an
> independant resolution, and bitdepth. This is equivalent to the
> "standard" windows multiscreen modes. We wanted to have screen 1=
> 1024x768 for the control monitor, then the last 3 screens set to
> 1280x1024. In this mode if you maximise a window of any application it
> maximises only to fill up the screen its located on
> stretch mode = up to 4 screens, each screen must be the same resolution
> and bitdepth. You end up with 1 wide 1x4 desktop. If you maximise a window
> in this mode it streteches and maximises across the whole 4 screens.
> With the PCI express matrox QID the multiscreen mode causes each vic
> window that you open to pop up on the primary screen, then if you drag it
> around it leaves trails and video locks up and causes screen corruption
> all over.
> The multiscreen mode did not have this problem. Last time i looked matrox
> had not updated the driver that casued this problem, and i am pretty sure
> its caused by the driver, not for example a hardware issue.
> Peter
> >> what's the difference between strech mode and multiscreen mode??
> >> To: "Derek Piper" <dcpiper at indiana.edu>; "Todd Zimmerman"
> >> <toddz at sfu.ca>
> >> Sent: Friday, June 10, 2005 3:49 AM
> >> Subject: re[2]: [AG-TECH] Multi Display Cards Recommendation
> >> > We used the new matrox PCI express variation of the (QID) matrox
> >> card.
> >> > It works fine in the horizontal stretch mode, but in the multiscreen
> >> mode
> >> > the vic windows corrupt the screens all over with screen courruption
> >> > occuring as you drag windows around. We tried to use the
> >> multiscreen
> >> > mode, so we could have1 screen for the control monitor at a lower
> >> res
> >> than
> >> > the other 3 screens.
> >> > Also the pci express driver dont support 1400x1050 which is comon in
> >> new
> >> > projectors today. I emailed matrox repeatedly about them upgrading
> >> thier
> >> > drivers to correct the problem, but all i get from them is that
> >> "they
> >> are
> >> > not aware on any problems with the product". This is what i call
> >> > "weasonable" behavior
> >> > Peter
> >> > >> What Matrox card did you get that you weren't happy with? We
> >> > >> recently
> >> > >> got a Matrox QID card (AGP) in our node and it works great. 4 x
> >> DVI
> >> > >> outputs. We have a Matrox Millenium P650 PCI to drive the
> >> 'operators
> >> > >> console' TFT, so it's a 5 display machine.
> >> > >> Derek
> >> > >> Todd Zimmerman wrote:
> >> > >> > Hey all,
> >> > >> > I'm just writing up a suggested hardware list and am not sure
> >> what
> >> > >> to
> >> > >> > suggest for a multi-out (tri or quad) video card - especially
> >> since
> >> > >> the
> >> > >> > last experience I had with a quad out card (from Matrox) was
> >> less
> >> > >> than
> >> > >> > satisfactory.
> >> > >> > All of our display machines are G5's - so we just add a second
> >> dual
> >> > >> > display card to get 4 outputs, which works well. However, for
> >> a
> >> > >> Windows
> >> > >> > display computer, I'm not sure this would work.
> >> > >> > Any recommendations??
> >> > >> > Thanks,
> >> > >> > Todd
> >> > >> Derek Piper - dcpiper at indiana.edu - (812) 856 0111
> >> > >> IRI 323, School of Informatics
> >> > >> Indiana University, Bloomington, Indiana
