[AG-TECH] Gentoo: emerge fails on rat. I only need VenueServer and BridgeServer
West Suhanic
giraffe911 at rogers.com
Sat Jun 11 14:02:47 CDT 2005
Hi Jason:
The exact gentoo error is:
gcc -O2 -march=pentium4 -fomit-frame-pointer -W -Wall -Wbad-function-cast -W
missing-prototypes -Werror -DHAVE_CONFIG_H -I/var/tmp/portage/rat-4.2.22-r3
/work/ag-media/common/src -I/var/tmp/portage/rat-4.2.22-r3/work/ag-media/tc
l-8.0/generic -I/var/tmp/portage/rat-4.2.22-r3/work/ag-media/tk-8.0/generic
-c
voxlet.cgcc -O2 -march=pentium4 -fomit-frame-pointer -W -Wall -Wbad-function
-cast -Wmissing-prototypes -Werror -DHAVE_CONFIG_H -I/var/tmp/portage/rat-4
.2.22-r3/work/ag-media/common/src -I/var/tmp/portage/rat-4.2.22-r3/work/ag-
media/tcl-8.0/generic -I/var/tmp/portage/rat-4.2.22-r3/work/ag-media/tk-8.0/
generic -c auddev_ixj.c
In file included from auddev_ixj.c:19:
/usr/include/linux/ixjuser.h:353: error: parse error before '*' token
make: *** [auddev_ixj.o] Error 1
make: *** Waiting for unfinished jobs....
!!! ERROR: ag-media/rat-4.2.22-r3 failed.
!!! Function src_compile, Line 39, Exitcode 2
!!! Failed to make rat
!!! If you need support, post the topmost build error, NOT this status
message.
I also just tried emerging the various components instead of everything in
an attempt
to get the venue and bridge server operational. However it failed. When I
ran VenueServer
I got a toolkit initialization error.
regards,
west
----- Original Message -----
To: "West Suhanic" <wsuhanic at alumni.uwaterloo.ca>
Cc: <ag-tech at mcs.anl.gov>
Sent: Saturday, June 11, 2005 1:04 PM
Subject: Re: [AG-TECH] Gentoo: emerge fails on rat. I only need VenueServer
and BridgeServer
> What was the error message?
> -jason pepas
> On Sat, Jun 11, 2005 at 12:16:59AM -0400, West Suhanic wrote:
> > Hello All:
> > I tried the following emerge command:
> > emerge -aq ag-libs/agtk <-- This command fails when trying to emerge
rat. Please note
> > when I do emerge rat this too fails. uname -a yields: Gentoo 2.6.11-r3
> > I am trying to get my VenueServer running under gentoo. If I can it
would really
> > streamline my hardware set-up and get me institutional system admin
support.
> > I have two questions. The first question is: How can I emerge the
> > server without the stuff does not work? My second question is: Without
the AGtk client interface how do
> > I setup the VenueServer using vi to edit its configuration files?
> > regards,
> > West Suhanic
