[AG-TECH] BridgeServer.py question ...
Mike Daley
Mike.W.Daley at cs.cardiff.ac.uk
Thu Jun 9 04:29:14 CDT 2005
Hi Tom
We were in the process of setting up a bridge when I saw the
BridgeServer questions
I tried the Windows version today but although it appears to create a
bridge it cannot then get any services through so vic sits there with a
blank screen waiting for video. Has anyone got this version to work yet.
Or should I continue with plan A and get a LINUX machine running?
I've attached the log file.
All the best
Mike
Thomas D. Uram wrote:
>Actually, Rhys Hawkins of ANU contributed changes that make QuickBridge work on Windows,
>and that code has been committed to cvs. The resulting QuickBridge executable can be
>downloaded from here:
>http://www.mcs.anl.gov/fl/research/accessgrid/software/releases/2.3/patches/QuickBridge.exe
>Download the executable, save it to a suitable location (most likely the AG install dir),
>and reference it in your BridgeServer config file, and it should work fine.
>I have tested QuickBridge/BridgeServer on Windows to confirm that it works, but nothing
>beyond that. I'll be interested to hear feedback on how well it works.
>Thanks Rhys!
>Tom
>On 06/08/05 15:27, Michael Miller wrote:
>>Here's a note from Doug Kosovic regarding the trouble with QuickBridge
>>on Windows:
>>Hi Tom,
>>Thomas D. Uram" wrote:
>>>Oh, and it compiles in vs.net, too (contrary to my original posting),
>>>but fails to start in that case, too.
>>I'm pretty certain that the problem is that QuickBridge.c includes
>>winsock.h (i.e Winsock-1) but is linked against Ws2_32.lib (i.e Winsock-2).
>>So I think the following line:
>>#include <winsock.h>
>>needs to be changed to:
>>#include <winsock2.h>
>>#include <ws2tcpip.h>
>>I've had a similar problem with multicast on Windows before with a
>>program I wrote.
>>See the following for more details:
>>http://support.microsoft.com/default.aspx?scid=kb;en-us;Q257460
>>Nathan P Johnson wrote:
>>>I have a venue server running under Windows and have started a bridge
>>>server for it -- BridgeServer.py. There doesn't appear to be a port of
>>>QuickBridge for Windows however. We need to use Windows because the
>>>machine is also needed for some other license server software. Does
>>>anyone know of a Windows port of Quickbridge or a way to run
>>>BridgeServer.py under XP?
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20050609/d2fd605b/attachment.diff>
