[AG-TECH] AG installation problem on Fedora core 2
John Hodrien
johnh at comp.leeds.ac.uk
Wed Jun 8 11:55:56 CDT 2005
On Wed, 8 Jun 2005, Fabio Asnicar wrote:
> I suppose that it can be related to the AGNodeService.py
> but I can not run AGNodeService because the script is NOT present:
>> rpm -ql AccessGrid
The clue appears to be in the gnome shortcut:
[Desktop Entry]
Name=Node Service
Comment=Run the node service software
TryExec=AGServiceManager.py
Exec=AGServiceManager.py -n
Icon=/usr/share/AccessGrid/ag.ico
Terminal=false
Type=Application
Encoding=UTF-8
Categories=X-Access-Grid-Services;
I'm guessing that the AGServiceManager.py script acts as a NodeService when
you pass it the -n flag
Sure enough:
[ag at agnode2 ag]$ AGServiceManager.py --help
usage: AGServiceManager.py [options]
options:
-h, --help show this help message and exit
-d, --debug Set the debug level of this program.
-lLOGFILE, --logfile=LOGFILE
Specify a log file to output logging to.
--numlogfiles=NUMLOGFILES
Specify the number of log files to retain
--logfilesize=LOGFILESIZE
Specify the size of log files to retain
-cCONFIGFILE, --configfile=CONFIGFILE
Specify a configuration file for the program.
--version Print out what version of the toolkit this is.
-i, --insecure Use insecure communications.
--profile=PROFILE Specify a service profile.
-pPORT, --port=PORT Set the port the service manager should run on.
-n, --nodeService Run a node service interface too.
So it'll run as both a NodeService and a Service Manager.
Why didn't you just click on the entry in the menu if you weren't sure?
jh
"A fanatic is a person who can't change his mind and won't change the
subject." -- Winston Churchill
