[AG-TECH] AG installation problem on Fedora core 2
Fabio Asnicar
fabio.asnicar at elettra.trieste.it
Wed Jun 8 09:27:29 CDT 2005
hi to all.
I have a problem in AG installation.
I am working on PC with linux Fedora core 2
Linux version 2.6.10-1.9_FC2smp (bhcompile at porky.build.redhat.com) (gcc
version 3.3.3 20040412 (Red Hat Linux 3.3.3-7)) #1 SMP Thu Jan 13
18:15:45 EST 2005
I done what described on:
Fedora Core 1, 2 & 3 AGTk 2.3 RPMs
http://www.itee.uq.edu.au/~agn/ag_fedora/fedora_instructions.html
I run VenueClient.py and imported the certificates from another AG
(working) installation (on windows)
then, when i try to set up my node the answer is:
Please, specify node service URL
Address: https://localhost:11000/NodeService
Can not open node management
at https://localhost:11000/NodeService
and the shell:
<Fault SOAP-ENV:Client: Method Not Found: NodeService:IsValid : exceptions.KeyError 'NodeService' <traceback object at 0xb7976324>>
<Fault SOAP-ENV:Client: Method Not Found: NodeService:IsValid : exceptions.KeyError 'NodeService' <traceback object at 0xb797634c>>
<Fault SOAP-ENV:Client: Method Not Found: NodeService:IsValid : exceptions.KeyError 'NodeService' <traceback object at 0xb7976374>>
<Fault SOAP-ENV:Client: Method Not Found: NodeService:IsValid : exceptions.KeyError 'NodeService' <traceback object at 0xb797639c>>
I suppose that it can be related to the AGNodeService.py
but I can not run AGNodeService because the script is NOT present:
> rpm -ql AccessGrid
/usr/bin/AGServiceManager.py
/usr/bin/BridgeServer.py
/usr/bin/CertificateRequestTool.py
/usr/bin/GoToVenue.py
/usr/bin/NodeManagement.py
/usr/bin/NodeSetupWizard.py
/usr/bin/QuickBridge
/usr/bin/VenueClient.py
/usr/bin/VenueManagement.py
/usr/bin/VenueServer.py
/usr/bin/VenueVNCServer.py
/usr/bin/agpm.py
/usr/bin/certmgr.py
(in attach the complete list)
any idea?
many thanks for help!
ciao,
FA_
AccessGrid-2.3-7
globus-accessgrid-2.4-8
Dr. Fabio Asnicar
Software For Measurements - GRIDCC project
Sincrotrone Trieste S.C.p.A. - Area Science Park
34012 Basovizza - Trieste (Italy)
Tel: +39 0403758351 Fax: +39 0403758565
URL: http://www.elettra.trieste.it
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20050608/7cf376df/attachment.htm>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20050608/7cf376df/attachment.obj>
