[Fwd: [AG-TECH] Change to alternate bridge for NCSA venues]
Michael Miller
mimiller at ncsa.uiuc.edu
Mon Jul 25 16:30:20 CDT 2005
ok, so this may portend a theme for the next few weeks, I had to move
the machine to a different jack, and was allocated a new ip address.
The info has been updated on the AGSchedule venues page:
http://agschedule.ncsa.uiuc.edu/venues.asp
Please consult this page for the most up to date information.
Michael Miller
NCSA
We have moved the machine that bridges NCSA venues for inSORS and other
machines that cannot use a bridge through the VenueClient. The new ip
address is 141.142.222.xxx?. The information has been updated on the
If you are using the venuesbridge/NCSA bridge through the venue client,
you should not need to make any changes to your firewall. The
venues-bridge/NCSA bridge will move within the next two weeks.
Due to a bug with the port allocation component, use of either
venuesbridge/NCSA or venues-bridge/NCSA may require opening additional
ports in your firewall for those machines. Please contact us if you have
further questions about this or experience problems with either of these
bridges.
Thanx,
Michael Miller
System Engineer
Video Technology Services
Persistent Infrastructure Directorate
National Center for Supercomputing Applications
University of Illinois - UC
217-649-0747
"If you're clear in your vision and trust the people in your team with clear objectives, they will invariably do their best to achieve everything desired, and usually deliver everything you could have hoped for and even more." -Paul Debevec
Thanx,
Michael Miller
System Engineer
217-649-0747
