[AG-TECH] XAP control by means of AMX system
Garry Peirce
peirce at maine.edu
Thu Jan 20 07:26:42 CST 2005
ClearOne makes an external Ethernet interface (XAP-Net ?) for the XAP which
connects to the XAPs Glink port.
In other systems where I have both an XAP and a PSR, I connect the AMX to
the XAP and use the serial port on the PSR, giving full control of both
devices to either AMX or the device on the PSR's serial port.
_____
From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On Behalf
Of Osland, CD (Chris)
Sent: Thursday, January 20, 2005 5:28 AM
To: 'Natalia Costas Lago'; ag-tech
Subject: RE: [AG-TECH] XAP control by means of AMX system
We're about to install not an AMX system but a Crestron and
I've agreed with the installers that they can use the other
interfaces on the XAP-800 and I'll use the serial port; I don't
believe there is any need to share the serial port.
Cheers
Chris
____________________________________________________________________
Chris Osland Office tel: +44
(0) 1235 446565
Digital Media and Access Grid Medialab tel: +44 (0)
1235 446459
BIT Department Access Grid room tel: +44
(0) 1235 445666
e-mail: C.D.Osland at rl.ac.uk Fax: +44
(0) 1235 445597
CCLRC Rutherford Appleton Laboratory (Bldg. R18)
Chilton, DIDCOT, Oxon OX11 0QX, UK
[The contents of this email are confidential and are for the use of the
intended recipient only.
If you are not the intended recipient do not take any action on it or show
it to anyone else,
but return this email to the sender and delete your copy of it.]
-----Original Message-----
From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov]On Behalf
Of Natalia Costas Lago
Sent: 20 January 2005 10:21
To: ag-tech
Subject: [AG-TECH] XAP control by means of AMX system
Hi everybody,
I wonder whether someone out there have an AMX system to control the Gware.
Is there any way to share the serial port in order to allow control from the
AMX and from the control PC at the same time?. Has anyone tried this
successfully?
Thanx in advance.
Kind regards,
Natalia.
Natalia Costas Lago
email: natalia at cesga.es
Centro de Supercomputacion de Galicia (CESGA)
Avenida de Vigo, s/n Campus Sur
15706 Santiago de Compostela - SPAIN
Tel: +34 981 56 98 10
Fax: +34 981 59 46 16
http://www.cesga.es/
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20050120/7bf18792/attachment.htm>
