[AG-TECH] BridgeServer not bridging?
Socrates
socratez at gmail.com
Thu Jan 20 04:42:23 CST 2005
Hi Tom:
First, I followed the sample I found in the document entitled "How to
Run a Bridge Server". On page 2 the format is described as:
[BridgeServer]
# the id field is assigned by the system; users can omit this line
id = <unique id of this bridge server>
name = <name of your institution>
location = <location of your institution>
qbexec = /usr/bin/QuickBridge
# ONE of the following mutually exclusive options can be specified
venue = <URL of venue to bridge>
venueFile = <file containing URLs of venues to bridge>
venueServer = <URL of venue server to bridge>
venueServerFile = <file containing URLs of venue servers to bridge>
The latter part, that of the mutually exclusive parts, does not seem
to agree with the format described in AccessGrid/bin/BridgeServer.py.
There I read:
[BridgeServer]
name = Argonne
location = Chicago
# use this port range for the bridge server as a whole
portMin = 30000
portMax = 40000
# Lobby of ag-2 server
[https://ag-2:8000/Venues/default]
type = Venue
# use this special port range for this venue
portMin = 24000
portMax = 24006
# Entire transitional venue server
[https://vv2.mcs.anl.gov:9000/VenueServer]
type = VenueServer
Socrates
On Wed, 19 Jan 2005 17:39:29 -0600, Thomas D. Uram <turam at mcs.anl.gov> wrote:
> Socrates:
> I'd like to update the document if there's a problem. I know the document describes the
> config file used by the BridgeServer in both versions 2.2 and 2.3. If you used the
> appropriate example config, and there was a problem with it, let me know so I can fix it.
> Thanks,
> Tom
> Socrates wrote:
> > Hi,
> > Thanks for the response.
> > In my case the problem has to do with wrong syntax in the
> > BridgeServer's config file. I was following the guidelines I found in
> > one of the docs in the toolkit describing the BridgeServer, but
> > unfortunately the document is outdated.
> > The source code (AccessGrid/bin/BridgeServer.py) has a working sample
> > config in the beginning.
> > QuickBridge process doesn't get killed though when BridgeServer quits.
> > Thanks,
> > Socrates.
> > On Wed, 19 Jan 2005 13:00:55 -0800, Todd Zimmerman <toddz at sfu.ca> wrote:
> >>Not sure if this is your issue - but I've just run into something very
> >>similar - it was caused by our bridgeserver certificate not being
> >>authorized to connect to the venueserver (two different machines - two
> >>different certificates).
> >>I added the bridgeserver DN to the venueserver administrators list and
> >>it worked after that.
> >>Giving administrator access is a bit extreme, obviously - and I'd like
> >>to narrow the scope of authorization; however, I wasn't sure which
> >>'Actions' the bridgeserver was required to be authorized for. Any
> >>advice from other admins would be great!
> >>Todd
> >>Collaboration & Visualization Technician
> >>WestGrid - www.westgrid.ca
> >>IRMACS - www.irmacs.com
> >>Ph. 604.268.6979
> >>Todd Zimmerman - toddz at sfu.ca
> >>Socrates wrote:
> >>>Hi,
> >>>I'm trying to run a bridge on my local server but it doesn't seem to work.
> >>>I start the BridgeServer.py script with a config file containing the
> >>>URI of the server (want all Venues bridged). I start the Client on
> >>>another machine but the "unicast" option in the menu is still grayed
> >>>out.
> >>>WiKi says that the Lucky Labrador Venue is bridged by Argonne:
> >>>( http://www-unix.mcs.anl.gov/fl/research/accessgrid/wiki/moin.cgi/BridgedVenues
> >>>Starting my Client on that room doesn't enable "unicast" on the menu either.
> >>>Any ideas? This is all Fedora Core 3. No errors reported in
> >>>BridgeServer.log, VenueServer.log or VenueClient.log.
> >>>Thanks,
Socrates.
