[AG-TECH] capture cards..
    Porfirio Gaona
    pgg at ixtli.unam.mx
    Wed Jan 19 23:11:48 CST 2005
HI,
Thanks for the fast response. I have a normal  Pnnacle PCTV standar, but
it has another chipset, it has the 7133.  Someone with this chipset has
taken succesful?
Well, it's a good idea to include the venueclient but I have problems with
my available PCI slots.
In Mexico, it is hard to find capture cards with multiple inputs.  In some
cases, I read about the Eagle CArd or another that I don't remember by
now.
Thanks in advance
Porfirio Gaona
IXTLI UNAM Mexico
On Thu, 20 Jan 2005, Douglas Kosovic wrote:
> Hi Porfirio
> > I have problems to find capture cards based on 878 chipset.  I've tried to
> > find Hauppage WinTV and Pinnacle PCTV Pro without successful.
> > I have a machine with 3 PCI 64 bit/66 MHz (PCI-X slots) and 2 PCI 32
> > bit/33 MHz (PCI Slots).
> > I have read about some Osprey 100 capture card, but in the same case, I
> > think that is discontinued.
> > Do you have a suggerence?
> A standard Pinnacle PCTV will suffice, no need for the Pro version,
> unfortunately, it might be discontinued as well.
> The BT878 based ProLINK PixelView PlayTV pro is still around, see:
> http://www.prolink-usa.com/english/product/mmpak/ppro.htm
> There are probably others still around.
> > I'm installing Fedora Core 3 in our Video PC.  I think that in this PC
> > isn't necessary have audio card.  The audio card will be managed by our
> > Audio PC and our Control PC (with the Gentner).
> It's probably most convenient to run rat on the same PC as the one running
> the VenueClient.
> Doug
