[AG-TECH] BridgeServer not bridging?
Socrates
socratez at gmail.com
Wed Jan 19 17:13:21 CST 2005
Thanks for the response.
In my case the problem has to do with wrong syntax in the
BridgeServer's config file. I was following the guidelines I found in
one of the docs in the toolkit describing the BridgeServer, but
unfortunately the document is outdated.
The source code (AccessGrid/bin/BridgeServer.py) has a working sample
config in the beginning.
QuickBridge process doesn't get killed though when BridgeServer quits.
Socrates.
On Wed, 19 Jan 2005 13:00:55 -0800, Todd Zimmerman <toddz at sfu.ca> wrote:
> Not sure if this is your issue - but I've just run into something very
> similar - it was caused by our bridgeserver certificate not being
> authorized to connect to the venueserver (two different machines - two
> different certificates).
> I added the bridgeserver DN to the venueserver administrators list and
> it worked after that.
> Giving administrator access is a bit extreme, obviously - and I'd like
> to narrow the scope of authorization; however, I wasn't sure which
> 'Actions' the bridgeserver was required to be authorized for. Any
> advice from other admins would be great!
> Todd
> Collaboration & Visualization Technician
> WestGrid - www.westgrid.ca
> IRMACS - www.irmacs.com
> Ph. 604.268.6979
> Todd Zimmerman - toddz at sfu.ca
> Socrates wrote:
> > Hi,
> > I'm trying to run a bridge on my local server but it doesn't seem to work.
> > I start the BridgeServer.py script with a config file containing the
> > URI of the server (want all Venues bridged). I start the Client on
> > another machine but the "unicast" option in the menu is still grayed
> > out.
> > WiKi says that the Lucky Labrador Venue is bridged by Argonne:
> > ( http://www-unix.mcs.anl.gov/fl/research/accessgrid/wiki/moin.cgi/BridgedVenues
> > Starting my Client on that room doesn't enable "unicast" on the menu either.
> > Any ideas? This is all Fedora Core 3. No errors reported in
> > BridgeServer.log, VenueServer.log or VenueClient.log.
> > Thanks,
Socrates.
