[AG-TECH] rat not displaying
Wesley Skoczen
wesley.skoczen at sheridanc.on.ca
Fri Jan 14 10:46:08 CST 2005
Hi Cindy
I had similar problem with my Gateway laptop, when I have switched to
wireless connection rat was working as it should. so simply try to use
different network card.
Hope it helps
Wesley
Wesley Skoczen
Applied Research, Knowledge Transformation Environment
Sheridan Institute of Advanced Learning, Oakville, ON
(905) 845 9430 ext. 8704
_________________________________________________
Cindy Sievers wrote:
> Hi everyone,
> I am trying to help a colleague in Isreal set up a pig node. He is
> running windows xp sp1, has no multicast. He has AGtk2.3 installed and
> it is working ok except that rat doesn't display on his machine. He
> has the audio service enabled, has a headset plugged into the
> integrated audio on his hp machine, and the rat.exe, ratui.exe, and
> ratmedia.exe all show up as processes running on his task manager.
> But the rat tool just doesn't display on his machine. He also has his
> windows firewall turned off.
> He can use the unicast bridge to enter a venue, he can transmit and
> receive video fine.
> Am I missing something here? If it were a port issue, the rat tool
> would still at least be displayed, wouldn't it? Any suggestions?
> Thanks,
> Cindy
> Cindy Sievers Los Alamos National Laboratory
> sievers at lanl.gov Group CCS-1 MS B287
> tel:505.665.6602 Advanced Computing
> fax:505.665.4939 Los Alamos, NM 87544
