[AG-TECH] VRVS via AG
    Andrew Rowley
    Andrew.Rowley at manchester.ac.uk
    Thu Jan  6 09:31:46 CST 2005
I would imagine that the H.323 VRVS users would be able to connect to the
Access Grid in one of these bridged rooms.  The page
http://www.vrvs.org/Documentation/VAG/#chap3 describes how to set up an
H.323 client to connect to an Access Grid room using VRVS.
I would not think that is was possible to connect Access Grid users to a
VRVS only room.  In this case, I would advise choosing one of the Access
Grid - VRVS rooms instead.
Andrew :)
Access Grid Support Centre,
RSS Group,
Manchester Computing,
Kilburn Building,
University of Manchester,
Oxford Road,
Manchester,
M13 9PL,
UK
Tel: +44(0)161-275 0685
Email: Andrew.Rowley at manchester.ac.uk
-----Original Message-----
From: Jeffrey Bary [mailto:Jeffrey.Bary at nyu.edu]
Sent: 06 January 2005 13:23
To: Bob Riddle; Andrew Rowley
Cc: ag-tech at mcs.anl.gov; Jeffrey.Bary at nyu.edu
Subject: Re: [AG-TECH] VRVS via AG
I'm interested in bridging a VRVS room into the AG rather than an AG
room into VRVS. I believe that (e.g.) the Fog Room in VRVS is not
available to AG only attendees.
Also, any thoughts on H.323 VRVS users using one of these bridged
rooms. I'm going to give it a try later today time permitting.
We've been asked to support a physics event in one of our buildings
that is not multicast ready and the group appears to be VRVS users.
-Jeff
>all you need to do is tell support at vrvs.org which room(s) you would
>like to be bridged.  For example, all of the "rooms" in the
>Internet2 "Community" are bridged and you are welcome to make use of
>these - juts remember to send me a note!
>Andrew Rowley wrote:
>>Hi,
>>I don't think that this is a VRVS-Access Grid room.  To see the list of
VRVS
>>rooms that can be used with Access Grid, go to http://www.vrvs.org/ and
>>login, then click on "Enter" on the left menu bar and select the
>>"VAccessGrid" in the top right hand corner (quite small, above options).
>>This lists the Virtual Venues that can be used for Access Grid - VRVS
>>interaction.
>>I am guessing that there might be a way to add to this list of venues.  I
>>would be interested in knowing how this might be done...
>>Andrew
>>RSS Group,
>>Kilburn Building,
>>Oxford Road,
>>Manchester, M13 9PL, UK
>>From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On
Behalf
>>Of Jeffrey Bary
>>Sent: 05 January 2005 22:20
>>To: ag-tech at mcs.anl.gov
>>Subject: [AG-TECH] VRVS via AG
>>Can I get to a VRVS venue via the AG ? In particular the Fog Room.
>>It has a couple of H.323 sources. Will that work ?
>>-Jeff
>Bob Riddle (bdr at internet2.edu)    Technologist,Internet2
>1000 Oakbrook Drive, Suite 300    Ann Arbor, Michigan  48104
>Business Phone: 734.913.4257      Fax Number:  734.913.4255
>"Math illiteracy affects 7 out of every 5 people"
