[AG-TECH] Beacon 1.1 for Windows
Andrew Rowley
Andrew.Rowley at manchester.ac.uk
Thu Jan 6 06:41:15 CST 2005
Are you sure that "Nothing" happens? Once it is installed, you need to
click on the "Install Beacon Service (AutoStart)" link and then click on
"Manually Start Beacon Service". There will be no output if all goes well.
To see if the beacon is working, go to http://beacon.dast.nlanr.net/ and
look down the page for your machine's DNS name and IP address. It may take
a couple of minutes to appear. It should also appear under the link "Beacon
Info" on this page.
If this is still not working, you can go to "Control Panel" -->
"Administrative Tools" --> "Event Viewer" and click on "Application" on the
left. This should list any errors from the beacon.
Andrew G D Rowley :-)
Access Grid Support Centre,
RSS Group,
Manchester Computing,
Kilburn Building,
University of Manchester,
Oxford Road,
Manchester,
M13 9PL,
UK
Tel: +44(0)161-275 0685
Email: Andrew.Rowley at manchester.ac.uk
_____
From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On Behalf
Of Thomas L. James
Sent: 05 January 2005 23:42
To: ag-tech at mcs.anl.gov
Subject: [AG-TECH] Beacon 1.1 for Windows
I have tried to install the Python version of Beacon 1.1 for windows with no
luck. It installs fine but when I try to run it nothing happens.
Any suggestions?
Tom James
Research Scientist (Network/System Administrator)
Center for Rural Health Research and Education
http://www.health.uwyo.edu/
1.307.766.9602
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20050106/d19d0328/attachment.htm>
