[AG-TECH] SW Firewall + AG2.3
Derek Piper
dcpiper at indiana.edu
Tue Jan 4 08:34:45 CST 2005
The ports are usually dynamic, so if you are setting absolute port
numbers then it won't work if you're changing venues.
If it's a Windows XP box, then install service pack 2 since then you
can set exceptions for specific programs (and it will prompt you to do so).
For Linux machines if you allow traffic with a destination of
224.0.0.0/8 for higher numbered ports, i.e. 50000-65535 then you should
be okay. If that's not fine grained enough you can always use 'lsof' and
grep for the exact port numbers and write a script that modifies your
firewall (I did one for a bridge)
Derek
Natalia Costas Lago wrote:
> When I try to install a sw firewall on a PIG the settings are wrong..
> the media tools work only for a while.. any idea about what must be
> going on?
> Kind regards,
> Natalia.
Derek Piper - dcpiper at indiana.edu - (812) 856 0111
IRI 323, School of Informatics
Indiana University, Bloomington, Indiana
