[AG-TECH] Outside AV not working
    Donald Roeber
    droeber at isc.upenn.edu
    Tue Feb 22 12:51:47 CST 2005
Sorry, that should be "I'm now using..."
On Feb 22, 2005, at 1:04 PM, Donald Roeber wrote:
> This seems to have fixed the problem.  I'm not using 224.2.0.0 -
> 224.2.0.0.2 and my external testers are confirming that this works for
> them.
> On Feb 21, 2005, at 6:22 PM, Thomas D. Uram wrote:
>> Hi Don:
>> I believe (based on other conversations with you) that you're using
>> multicast addresses similar to 224.0.0.x on your server.  This is,
>> apparently, a problem.
>> From the cisco Guidelines for Enterprise IP Multicast Address
>> Allocation
>> (http://www.cisco.com/en/US/tech/tk828/
>> technologies_white_paper09186a00802d4643.shtml), it looks like you
>> should avoid 224.0.0.0-224.0.0.255, which "is used by network
>> protocols on a local subnet segment".
>> This same document claims that the 'global' range is
>> 224.1.0.0-238.255.255.255, so addresses there should work for you.
>> There are more details in RFC3171, if you're interested.
>> Let us (ag-tech) know if this fixes your problem.
>> Tom
>>> We're running the latest AccessGrid Toolkit on MacOS X, as both a
>>> VenueServer and a UniCast Bridge for that VenueServer.  The server
>>> is multicast enabled, and so are clients on the upenn.edu network.
>>> Clients on the upenn.edu network can connect to the VenueServer and
>>> use RAT and VIC just fine.  Unfortunately, for people outside of the
>>> Penn network, audio and video doesn't work, but they can still use
>>> the text chat built into the VenueClient.  We don't have any
>>> firewalls or anything like that in place.  Because of a bug in the
>>> MacOS X version of the AGToolKit we're using manual multicast
>>> addressing for each venue.  Each venue is assigned a unique IP
>>> address for audio and video, and a unique even numbered port number
>>> for each service as well.
>>> Any help would be greatly appreciated.
> Donald Roeber
> ISC Networking
Donald Roeber
ISC Networking
