[AG-TECH] VIC performance
    Natalia Costas Lago
    natalia at cesga.es
    Mon Feb 21 09:55:46 CST 2005
CPU is usually between 20 and 50% (VIC 1.1.3 always display around 20%.. and VIC 1.1.5 displays around 50% CPU usage)..
I doesnt look like a resources issue to me...
  ----- Original Message -----
  To: Natalia Costas Lago ; ag-tech
  Sent: Monday, February 21, 2005 4:48 PM
  Subject: RE: [AG-TECH] VIC performance
  To me that would indicate that the processor, memory
  and graphics card are NOT the problem.
  Cheers
  Chris
  ____________________________________________________________________
  Chris Osland                                               Office tel: +44 (0) 1235 446565
  Digital Media and Access Grid                          Medialab tel: +44 (0) 1235 446459
  BIT Department                                     Access Grid room tel: +44 (0) 1235 445666
  e-mail:   C.D.Osland at rl.ac.uk                                       Fax: +44 (0) 1235 445597
  CCLRC Rutherford Appleton Laboratory (Bldg. R18)
  Chilton, DIDCOT, Oxon OX11 0QX, UK
  [The contents of this email are confidential and are for the use of the intended recipient only.
  If you are not the intended recipient do not take any action on it or show it to anyone else,
  but return this email to the sender and delete your copy of it.]
    -----Original Message-----
    From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov]On Behalf Of Natalia Costas Lago
    Sent: 21 February 2005 15:34
    To: ag-tech
    Subject: Fw: [AG-TECH] VIC performance
    forgot to cc the list :)))
    To: Robert Olson
    Sent: Monday, February 21, 2005 4:33 PM
    Subject: Re: [AG-TECH] VIC performance
    The machine is dual P4 3Ghz with 2 GB of RAM. The videostreams are 24 fps when displayed on the TFT but, when moved to the screen the frames per second lowers.
    The videocard is an Nvidia Quadro NVS.
    Other node in Portugal appreciated the same effect.
    We welcome any node to test this at https://accessgrid.cesga.es:8000/Venues/default. I am restarting my node, so I will need some time to join again.
    Kind regards,
    Natalia.
      Cc: ag-tech
      Sent: Monday, February 21, 2005 4:23 PM
      One way to tell what is going on is to mute all of the video streams. when muted, all vic is doing is parsing the packet streams, and not decoding the h261 (as I recall anyway). It is definitely not rendering them. If you still see frame loss with streams muted, it is most likely the network at fault.
      You can also bring up the CPU monitor; if you are seeing 100% CPU with the video streams being displayed, that's a clue that the computer is not keeping up.
      --bob
      On Feb 21, 2005, at 8:45 AM, Natalia Costas Lago wrote:
        Hi everybody,
        I have quite a huge problem. VIC is performing in a strange way, I have 13 windows on my display and each videostream has been reduced its fps rate. It seems like VIC discarded frames due to performance issues or something like that.
        Any help about this will be greatly appreciated.
        Kind regards,
        Natalia.
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20050221/e026ff8e/attachment.htm>
