[AG-TECH] VIC performance
    Osland, CD (Chris)
    C.D.Osland at rl.ac.uk
    Mon Feb 21 09:48:26 CST 2005
To me that would indicate that the processor, memory
and graphics card are NOT the problem.
Cheers
Chris
____________________________________________________________________
Chris Osland                                               Office tel: +44 (0) 1235 446565
Digital Media and Access Grid                          Medialab tel: +44 (0) 1235 446459
BIT Department                                     Access Grid room tel: +44 (0) 1235 445666
e-mail:   C.D.Osland at rl.ac.uk                                       Fax: +44 (0) 1235 445597
CCLRC Rutherford Appleton Laboratory (Bldg. R18)
Chilton, DIDCOT, Oxon OX11 0QX, UK
[The contents of this email are confidential and are for the use of the intended recipient only.
If you are not the intended recipient do not take any action on it or show it to anyone else,
but return this email to the sender and delete your copy of it.]
-----Original Message-----
From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov]On Behalf Of Natalia Costas Lago
Sent: 21 February 2005 15:34
To: ag-tech
Subject: Fw: [AG-TECH] VIC performance
forgot to cc the list :)))
----- Original Message -----
From: Natalia Costas Lago <mailto:natalia at cesga.es>
To: Robert Olson <mailto:olson at mcs.anl.gov>
Sent: Monday, February 21, 2005 4:33 PM
Subject: Re: [AG-TECH] VIC performance
The machine is dual P4 3Ghz with 2 GB of RAM. The videostreams are 24 fps when displayed on the TFT but, when moved to the screen the frames per second lowers.
The videocard is an Nvidia Quadro NVS.
Other node in Portugal appreciated the same effect.
We welcome any node to test this at  https://accessgrid.cesga.es:8000/Venues/default. I am restarting my node, so I will need some time to join again.
Kind regards,
Natalia.
To: Natalia Costas Lago <mailto:natalia at cesga.es>
Cc: ag-tech <mailto:ag-tech at mcs.anl.gov>
Sent: Monday, February 21, 2005 4:23 PM
One way to tell what is going on is to mute all of the video streams. when muted, all vic is doing is parsing the packet streams, and not decoding the h261 (as I recall anyway). It is definitely not rendering them. If you still see frame loss with streams muted, it is most likely the network at fault.
You can also bring up the CPU monitor; if you are seeing 100% CPU with the video streams being displayed, that's a clue that the computer is not keeping up.
--bob
On Feb 21, 2005, at 8:45 AM, Natalia Costas Lago wrote:
<?fontfamily><?param Arial><?smaller><?x-tad-smaller>Hi everybody,<?/x-tad-smaller><?/smaller><?/fontfamily>
<?fontfamily><?param Arial><?smaller><?x-tad-smaller>I have quite a huge problem. VIC is performing in a strange way, I have 13 windows on my display and each videostream has been reduced its fps rate. It seems like VIC discarded frames due to performance issues or something like that.<?/x-tad-smaller><?/smaller><?/fontfamily>
<?fontfamily><?param Arial><?smaller><?x-tad-smaller>Any help about this will be greatly appreciated.<?/x-tad-smaller><?/smaller><?/fontfamily>
<?fontfamily><?param Arial><?smaller><?x-tad-smaller>Kind regards,<?/x-tad-smaller><?/smaller><?/fontfamily>
<?fontfamily><?param Arial><?smaller><?x-tad-smaller>Natalia.<?/x-tad-smaller><?/smaller><?/fontfamily>
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20050221/4540f2db/attachment.htm>
