[AG-TECH] VenueVNCServer available
    Thomas D. Uram
    turam at mcs.anl.gov
    Wed Feb  9 10:08:14 CST 2005
Andrew:
I have the VenueVNC client installed on Gentoo, Windows, and OSX as part of the package.
Which OS are you using?  VenueVNC is different from the other shared apps, in that having
the client installed does not enable you to start sessions.  VenueVNC sessions are started
only by the server; the only indication that you have a client installed is when you try
to join a session, whether it succeeds or not.
Let me know details and we'll sort it out.
Tom
Andrew Patrick wrote:
> Although the VenueVNC client application is included in the AG2.3
> software package, it is not installed by default and there is no .app
> file to support installing in the usual fashion using agpm. Perhaps
> someone could make available a small ZIP file containing the appropriate
> Python and .app file so the client can be installed properly?
> Thomas D. Uram wrote:
>> The server component of the VenueVNC shared application is now
>> available for download:
>> http://www.mcs.anl.gov/fl/research/accessgrid/software/releases/2.3/patches/VenueVNCServer.py
>> This program is all Python code, so works similarly on the three
>> supported platforms:  Windows, Linux, and OSX.  Platform variations
>> are given here:
>> * Windows
>> - Depends on RealVNC (http://realvnc.com/)
>> - Looks for server executable in the RealVNC install directory
>>     (C:\Program Files\RealVNC\VNC4\WinVNC4.exe)
>> - Only the primary display can be shared
>> - Uses port 5900 for server
>> * Linux
>> - Depends on tightvnc (http://www.tightvnc.com) (other vnc packages
>>    may also work)
>> - Looks for server executable in /usr/bin/Xvnc
>> - Any virtual display can be shared via the '--display' option
>> - Uses port 5900+displaynumber for server (e.g. 5909 for display
>> number 9)
>> * OSX
>> - Depends on OSXvnc (http://www.redstonesoftware.com/osxvnc/OSXvnc.html)
>> - Looks for server executable in /Applications/OSXvnc.app/OSXvnc-server
>> Users should note the following with respect to security and VNC:
>> - VNC is regarded as a security risk
>>    (refer to http://www.realvnc.com/faq.html#security)
>> - Firewall holes must be opened to allow access to the VNC server from
>>    outside your network.  Ports are identified above in the plaform
>> notes.
>> ** Execution
>> VenueVNCServer.py will typically be executed as follows:
>>     python VenueVNCServer.py --venueUrl
>> https://someserver:8000/Venues/default
>> On OSX, the environment settings file must be sourced into your
>> environment
>> before running VenueVNCServer.py (the file is
>> /Applications/AccessGridToolkit.app/Contents/Resources/setupenv.sh).
>> A complete list of command-line options is available by passing the
>> '-h' option.
>> Bugs should be filed in the AccessGrid bugzilla database at
>> http://bugzilla.mcs.anl.gov/accessgrid .
