[AG-TECH] Re: Access Grid Invitation
    Mike Elmore
    mwelmore at lbl.gov
    Tue Feb  8 17:51:23 CST 2005
Sorry for sending this to ag-tech.  Replyed to all and forgot to remove ag-tech.
Mike
Mike Elmore wrote:
> Hi Oliver,
> Based on the response I got from ag-tech, it looks like you should do the power point
> presentations since you have IGPix.  Everyone else can connect to the URL you provide
> with a web browser.  If someone else has IGPix and would like
> to master the power point slides that will be fine.  If you run the power point slides
> Oliver, then the other sites will just to you when to advance the slides.
> See you all in the morning for me and evening for you.
> Thank you,
> Mike
> Oliver Jevons wrote:
> > Hi Mike,
> > IGPix simply rolls out the powerpoint slides onto a webpage which the
> > viewers load up in a browser ( This automatically updates at all sites
> > when the slide is changed.) so is AG version independant. Would we need
> > to download software to view presentations through AG2.x ?
> > Regards
> > Oliver
> > Mike Elmore wrote:
> > > Hello Oliver,
> > > We don't use insors anymore and I am not sure about IGPix and what it is
> > > compatible with.  Does anyone on ag-tech know about the compatibility issues with
> > > insors and ag 2.x?
> > > Thank you,
> > > Mike
> > >>Hi All,
> > >>what system is going to be used to run powerpoint presentations? We use
> > >>an inSORS node at IC, so IGPix would be our choice. Is this compatible
> > >>with the AG2.x presenter?
> > >>Cheers
> > >>Oliver
> > >>Mike Elmore wrote:
> > >>>Hello,
> > >>>I have reserved the Monte Carlo room for the 9th at 7am Pacific Time.  I have
> > >>>also sent a request to reserve the Full Sail Room for the 9th and the 18th.
> > >>>The Full Sail room is also a unicast capable room and will be used as a
> > >>>backup in case connectivity is lost to the Monte Carlo room.  We can also
> > >>>test the share presentation capability on the 9th.  I can put a power point
> > >>>presentation on the schedule or if you can upload one to the schedule.  Hope
> > >>>to see everyone on the 9th.
> > >>>Thank you,
> > >>>Mike
> > >>>>The 9th is good for us.
> > >>>>Regards,
> > >>>>Oliver
> > >>>>C1293900 at Queens-Belfast.AC.UK wrote:
> > >>>>>Greetings all,
> > >>>>>Apologies from Belfast for not being able to attend yesterday. I was
> > >>>>>involved in a meeting, but had someone here on standby. Unfortunately
> > >>>>>the network on which the access grid is on, went down yesterday (and is
> > >>>>>still down at the time of writing this email).
> > >>>>>You mentioned another test next week. I will be available on the
> > >>>>>Wednesday the 9th if you want to schedule another test, but not Thursday
> > >>>>>10th. However if you want to schedule it for the 10th I can arrange for
> > >>>>>someone to be here for it.
> > >>>>>Regards,
> > >>>>>Andrew Carson
> > >>>>>c1293900 at qub.ac.uk
> > >>>>>Belfast e-Science Centre
> > >>>>Oliver Jevons
> > >>>>Operations Manager
> > >>>>London e-Science Centre | http://www.lesc.ic.ac.uk/
> > >>>>020 7594 8409 | http://www.doc.ic.ac.uk/~omj
> > >>Oliver Jevons
> > >>Operations Manager
> > Oliver Jevons
> > Operations Manager
Type: text/x-vcard
Desc: Card for Mike Elmore
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20050208/f5a52db0/attachment.vcf>
