[AG-TECH] Re: Access Grid Invitation
    Mike Elmore
    mwelmore at lbl.gov
    Tue Feb  8 17:46:07 CST 2005
Hi Oliver,
Based on the response I got from ag-tech, it looks like you should do the power point
presentations since you have IGPix.  Everyone else can connect to the URL you provide
with a web browser.  If someone else has IGPix and would like
to master the power point slides that will be fine.  If you run the power point slides
Oliver, then the other sites will just to you when to advance the slides.
See you all in the morning for me and evening for you.
Thank you,
Mike
Oliver Jevons wrote:
> Hi Mike,
> IGPix simply rolls out the powerpoint slides onto a webpage which the
> viewers load up in a browser ( This automatically updates at all sites
> when the slide is changed.) so is AG version independant. Would we need
> to download software to view presentations through AG2.x ?
> Regards
> Oliver
> Mike Elmore wrote:
> > Hello Oliver,
> > We don't use insors anymore and I am not sure about IGPix and what it is
> > compatible with.  Does anyone on ag-tech know about the compatibility issues with
> > insors and ag 2.x?
> > Thank you,
> > Mike
> >>Hi All,
> >>what system is going to be used to run powerpoint presentations? We use
> >>an inSORS node at IC, so IGPix would be our choice. Is this compatible
> >>with the AG2.x presenter?
> >>Cheers
> >>Oliver
> >>Mike Elmore wrote:
> >>>Hello,
> >>>I have reserved the Monte Carlo room for the 9th at 7am Pacific Time.  I have
> >>>also sent a request to reserve the Full Sail Room for the 9th and the 18th.
> >>>The Full Sail room is also a unicast capable room and will be used as a
> >>>backup in case connectivity is lost to the Monte Carlo room.  We can also
> >>>test the share presentation capability on the 9th.  I can put a power point
> >>>presentation on the schedule or if you can upload one to the schedule.  Hope
> >>>to see everyone on the 9th.
> >>>Thank you,
> >>>Mike
> >>>>The 9th is good for us.
> >>>>Regards,
> >>>>Oliver
> >>>>C1293900 at Queens-Belfast.AC.UK wrote:
> >>>>>Greetings all,
> >>>>>Apologies from Belfast for not being able to attend yesterday. I was
> >>>>>involved in a meeting, but had someone here on standby. Unfortunately
> >>>>>the network on which the access grid is on, went down yesterday (and is
> >>>>>still down at the time of writing this email).
> >>>>>You mentioned another test next week. I will be available on the
> >>>>>Wednesday the 9th if you want to schedule another test, but not Thursday
> >>>>>10th. However if you want to schedule it for the 10th I can arrange for
> >>>>>someone to be here for it.
> >>>>>Regards,
> >>>>>Andrew Carson
> >>>>>c1293900 at qub.ac.uk
> >>>>>Belfast e-Science Centre
> >>>>Oliver Jevons
> >>>>Operations Manager
> >>>>London e-Science Centre | http://www.lesc.ic.ac.uk/
> >>>>020 7594 8409 | http://www.doc.ic.ac.uk/~omj
> >>Oliver Jevons
> >>Operations Manager
> Oliver Jevons
> Operations Manager
Type: text/x-vcard
Desc: Card for Mike Elmore
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20050208/b1820e8c/attachment.vcf>
