[AG-TECH] VenueVNCServer available
Thomas D. Uram
turam at mcs.anl.gov
Mon Feb 7 16:27:14 CST 2005
The server component of the VenueVNC shared application is now available for download:
http://www.mcs.anl.gov/fl/research/accessgrid/software/releases/2.3/patches/VenueVNCServer.py
This program is all Python code, so works similarly on the three
supported platforms: Windows, Linux, and OSX. Platform variations
are given here:
* Windows
- Depends on RealVNC (http://realvnc.com/)
- Looks for server executable in the RealVNC install directory
(C:\Program Files\RealVNC\VNC4\WinVNC4.exe)
- Only the primary display can be shared
- Uses port 5900 for server
* Linux
- Depends on tightvnc (http://www.tightvnc.com) (other vnc packages
may also work)
- Looks for server executable in /usr/bin/Xvnc
- Any virtual display can be shared via the '--display' option
- Uses port 5900+displaynumber for server (e.g. 5909 for display number 9)
* OSX
- Depends on OSXvnc (http://www.redstonesoftware.com/osxvnc/OSXvnc.html)
- Looks for server executable in /Applications/OSXvnc.app/OSXvnc-server
Users should note the following with respect to security and VNC:
- VNC is regarded as a security risk
(refer to http://www.realvnc.com/faq.html#security)
- Firewall holes must be opened to allow access to the VNC server from
outside your network. Ports are identified above in the plaform notes.
** Execution
VenueVNCServer.py will typically be executed as follows:
python VenueVNCServer.py --venueUrl https://someserver:8000/Venues/default
On OSX, the environment settings file must be sourced into your environment
before running VenueVNCServer.py (the file is
/Applications/AccessGridToolkit.app/Contents/Resources/setupenv.sh).
A complete list of command-line options is available by passing the '-h' option.
Bugs should be filed in the AccessGrid bugzilla database at
http://bugzilla.mcs.anl.gov/accessgrid .
