[AG-TECH] GLOBUS_HOSTNAME problems
Michael Miller
mimiller at ncsa.uiuc.edu
Tue Aug 16 12:52:08 CDT 2005
I've had the same trouble when trying to use an anonymous cert. not
sure how to fix tho'. What does nslookup give for your IP, and
conversely for your domain name? They should match up of course, but
I've seen the name resolve to a different IP before...
MYK
Darin Oman wrote:
> When I try to "manage my node," I'm told I need to specify the node
> service URL, then I'm told that the machine "can not open node
> management at https://..." I know this is a problem with DHCP
> machines. I've tried set GLOBUS_HOSTNAME and I've also tried to remove
> the environment variable. The problem there is that there is no
> reference anywhere to GLOBUS_HOSTNAME. No environment variable,
> nothing. I've tried removing and reinstalling the Globus parts as well
> as the toolkit a number of times. I've also dug through the registry.
> The result is always the same. Does anybody have any idea what I'm
> missing?
> Thanks,
> Darin
Thanx,
Michael Miller
System Engineer
Video Technology Services
Persistent Infrastructure Directorate
National Center for Supercomputing Applications
University of Illinois - UC
217-649-0747
"If you're clear in your vision and trust the people in your team with clear objectives, they will invariably do their best to achieve everything desired, and usually deliver everything you could have hoped for and even more." -Paul Debevec
