[AG-TECH] 'Warbled' Sound under Linux
Gavin W. Burris aka 86
ga5in at psu.edu
Tue Aug 16 08:54:00 CDT 2005
Consolidating some of your video capture slots with something like this:
http://www.icpamerica.com/products/accessories/IVC/IVC_200G.html
Then get a PCI soundcard that is known to work with the latest ALSA. I
recommend a Soundblaster 512 PCI. I have not had luck with the Audigy
cards at all.
I would try configuring and testing audio without other devices in the
computer. Other devices might be interfering with the audio or making
your motherboard squirrelly.
Cheers.
John Hodrien wrote:
> I've had this problem before, and managed to escape it through upgrading
> ALSA
> and friends. But now it's back again, on a machine that's caused me
> nothing
> but grief so far.
> Initially I was trying to use an onboard SB Audigy 24bit with ALSA. Sadly
> recording is not supported. Then I tried OSS, but despite claiming support
> for recording, it doesn't work.
> So I've bought a Terratec USB 5.1 MkII card (all PCI slots are used by
> capture
> cards) which uses the generic snd-usb-audio driver. Using ALSA rat
> leaves me
> shafted, as it doesn't even start up with a failed assertion. I might
> poke at
> this later although I suspect this is a painful road.
> Using OSS rat with ALSA (using OSS emulation) works, and recording works
> perfectly. Playback however is shoddy, with it sounding warbled. As
> far as I
> can gather it's trying to repair the audio (as it sound different with
> different repair schemes) but there's no packet loss. If I add
> redundancy to
> the stream, the audio sounds fine, as does it if I drop to 8kHz.
> Neither of these are a solution though. Anyone got any suggestions as
> to how
> to fix this?
> jh
Senior Systems Programmer
Penn State Visualization Group
http://viz.aset.psu.edu/ga5in
