[AG-TECH] 'Warbled' Sound under Linux
John Hodrien
johnh at comp.leeds.ac.uk
Tue Aug 16 04:39:51 CDT 2005
I've had this problem before, and managed to escape it through upgrading ALSA
and friends. But now it's back again, on a machine that's caused me nothing
but grief so far.
Initially I was trying to use an onboard SB Audigy 24bit with ALSA. Sadly
recording is not supported. Then I tried OSS, but despite claiming support
for recording, it doesn't work.
So I've bought a Terratec USB 5.1 MkII card (all PCI slots are used by capture
cards) which uses the generic snd-usb-audio driver. Using ALSA rat leaves me
shafted, as it doesn't even start up with a failed assertion. I might poke at
this later although I suspect this is a painful road.
Using OSS rat with ALSA (using OSS emulation) works, and recording works
perfectly. Playback however is shoddy, with it sounding warbled. As far as I
can gather it's trying to repair the audio (as it sound different with
different repair schemes) but there's no packet loss. If I add redundancy to
the stream, the audio sounds fine, as does it if I drop to 8kHz.
Neither of these are a solution though. Anyone got any suggestions as to how
to fix this?
jh
"Come friendly bombs, and fall on Slough!
It isn't fit for humans now,
There isn't grass to graze a cow.
Swarm over, Death." -- Sir John Betjeman
