[AG-TECH] Has Anyone got the WinTV PVR 150 to work with VIC?
    Christoph Willing
    willing at itee.uq.edu.au
    Mon Aug 15 18:30:16 CDT 2005
On 16/08/2005, at 12:48 AM, Proshanta Saha wrote:
> Hi Chris,
> Yes, I am using multiple WinTV PVR 150 cards in both Windows and Linux
> Environments. I'm going to try to debug the window environment VIC to
> see why VFW does not seem to like the caputer card at all. I would
> certainly like to use it under linux so that I can set the source
> while adding the service. I understand the concerns over IVTV's
> drivers, it still appears to be in a fairly beta release. However, if
> someone can point me to the particular modules using V4L drivers, I
> can try to see if I can convice it to use IVTV instead. Is the
> Berkeley repository for VIC still the defacto place for the CVS
> snapshots?
I think the Berkeley openmash version is currently only used for the
OSX release of the AG toolkit. The default version is based on the UCL
version, but with some changes - available via:
	http://www-unix.mcs.anl.gov/fl/research/accessgrid/software/cvs.html
or (for web viewing) at;
	http://fl-cvs.mcs.anl.gov/viewcvs/viewcvs.cgi/ag-media/
 From the vic directory, look in the video directory for all the
grabber-*.cpp files - they're the ones which integrate different
devices for vic - in particular grabber-video4lnux.cpp.
> While I'm debugging this I think I'll go on a hunting mission to find
> if we have some Hauppauge WinTV PCI (model 401) lying around. It
> appears to be missing from the shelves in most stores, probably gonna
> be hard to get through our authorized vendors. The politics of vendor
> list is quite messy, and we're generally restricted to only them. But
> before I do is there a list of cards that VIC supports under linux
> using V4L?
The main issue here is that the v4l driver assumes one of the BT878
family of chips on the video card. A number of manufacturers (including
Hauppauge) are now using a different chip, typically a Conexant brand
> In regards to VLC, you are allowed to use multiple instances and
> multiple streams, I'm trying to tinker with the tool to allow me to
> view multiple streams while its being sent to the destination IP. Nice
> tool, I think the DV and HDV group of the extended video
> producer/consumer service project has some literature, but not enough
> documentation on how to configure multipe streams.
Yes, it would be great to have a grabber application that needs just a
single instance to deal with multiple video streams.
chris
Christoph Willing                        Ph: +61 7 3365 8350
QPSF Access Grid Manager
University of Queensland
