[AG-TECH] Super PIG
John Hodrien
johnh at comp.leeds.ac.uk
Thu Aug 11 10:33:11 CDT 2005
On Thu, 11 Aug 2005, aspale1 wrote:
> Hello,
> I would just like to share with everyone that NCDM-UIC has successfully
> created a "super" PIG that has 2 webcams and an echo-cancellation
> microphone for small group AG sessions. I was not sure it was going to
> work but our sys admin here made the suggestion, and I happily discovered
> that this configuration worked. Although we are currently using a single
> display, there seem to be plans in the works to obtain another video
> display card that will allow for two displays (one for the node operator
> and one for the local participants). The two cameras really make a
> difference and do not seem to overpower the Dell Optiplex GX280 Pentium 4,
> 1 GB RAM PC (with hyperthreading enabled). Although have cameras that
> adjust would be nice, the solution is sufficient for the lab's purposes.
> The webcams that we are using are a Logitech Quickcam Pro 4000 (works
> perfectly) and the Creative Live Ultra for Notebooks (using the "Configure
> on Transmit" option in VIC prevents errors since the webcam driver cannot
> seem to "remember" the correct resolution and minimally makes VIC crash,
> and, in worse cases, makes Windows XP SP2 crash with a blue screen). The
> microphone is an echo-cancelling ClearOne AccuMic PC which works very
> well.
So how does Vic behave with that setup? Do you end up seeing one camera in
one vic, and t'other in t'other?
jh
"It is the mark of an educated mind to be able to entertain a thought without
accepting it." -- Aristotle
