[AG-TECH] Portal node listing update ...
Michael Braitmaier
braitmaier at hlrs.de
Mon Aug 8 12:07:06 CDT 2005
Hello Darran!
Nice idea with the GPS. Unfortunately I don't have a GPS receiver here at
hand.
Furthermore Google map seems to consider Europe being "burned soil".
There are no cities and streets available, except for the UK.
In this context making GPS coordinates a "must" in the node formular is not
very
lucky. I would appreciate it, GPS coordinates being optional at least until
everyone
has a easy chance of determining his GPS coordinates.
Best Regards
Michael
----- Original Message -----
From: "Darran Edmundson" <darran.edmundson at anu.edu.au>
To: <ag-tech at mcs.anl.gov>
Sent: Monday, August 08, 2005 4:33 PM
Subject: [AG-TECH] Portal node listing update ...
> Hi All,
> Thanks to all those who have taken the time to add
> a "Node Listing" to the portal. I've just finished a
> crude listings page that aggregates the data. http://agcentral.org/
> You'll find this under the new "nodes" tab on the main
> navigation bar. It's not pretty at the moment, but
> that'll change in the near future.
> I suspect that others will now want to start adding
> listings. To facilitate this, I've written up a How-To
> on "Adding a Node Listing":
> http://agcentral.org/help/how-to/node-listing
> Note, this document needs "reviewing" and
> "publishing" by one of the portal reviewers (you know
> who you are). Until then, it won't appear in the
> Help Center and is reachable only by logged-in
> members via the above link.
> I'm hoping to wake up tomorrow to vastly expanded
> node listings. Next will be a map of Access Grid
> nodes using the GPS coordinates ...
> Cheers,
> Darran.
