[AG-TECH] Re: your mail
Chris Rosenthal
cmr.evl at gmail.com
Mon Aug 8 10:11:19 CDT 2005
Just thought I would chime in that we have been living with that
problem (on XP) as well. Usually we workaround by leaving talk
checked and adjusting our outgoing volume.
Chris
On 8/8/05, Gavin W. Burris aka 86 <ga5in at psu.edu> wrote:
> I just had the same problem here! We tried all the sound, mixer, and
> rat options to no end. The funny thing is that this system was fine a
> week ago.
> I tried blowing away the Access Grid settings under Application Data, no
> go. Does anyone know where RAT stores its settings in the registry?
> Locatis, Craig (NIH/NLM/LHC) wrote:
> > We've experienced the same problem here at NLM on our XP
> > machine..............
> > -----Original Message-----
> > From: John Hodrien [mailto:johnh at comp.leeds.ac.uk]
> > Sent: Monday, August 08, 2005 7:27 AM
> > To: ag-tech at mcs.anl.gov
> > Subject: [AG-TECH] Re: your mail
> > On Mon, 8 Aug 2005, Peter DeSantis wrote:
> >>Hi,
> >>has anyone come across an issue with the AG 2.3 software where you find
> > that
> >>you can not receive (hear) audio from any other participants unless your
> >>local "talk" option is enabled. Also i would have expected full duplex
> >>audio operation to allow one to speak and receive audio simultaneously,
> > but
> >>it also appears that when you speak locally and start to transmit audio it
> >>cuts of the incoming audio. Is this normal ?
> > Definitely not normal. Have you got the dodgy software based echo
> > cancellation turned on in rat or something?
> >>Ive come across this on two XP based machines now. It dont appear to be a
> >>networking issue in that once talk is enable others can be heard fine. In
> >>both cases the machines had different audio cards, and one is single Pc
> > the
> >>other a 3 pc system.
> > Doesn't happen with any of our 2000 or linux based machines.
> > jh
> Senior Systems Programmer
> Penn State Visualization Group
> http://viz.aset.psu.edu/ga5in
Chris Rosenthal
Electronic Visualization Laboratory
University of Illinois - Chicago
Phone: 312.996.3002
