[AG-TECH] Certificate request
Victor Babson
vbabson at secsg.uga.edu
Wed Aug 3 22:04:07 CDT 2005
Hey Tom,
Thanks for the cert and thanks for the reply. I knew of the loose promise
of having a cert within 48 hours.
I am working on a documentation project and I am doing video captures for
folks who need it. I wanted to request an identity cert, show how to check
the status and then import it when ready.
I just started to worry that my request didn't get through since it had been
over 80 hours...
Your extra information helps me in writing my documentation, so thanks! But
before I include the ag-tech mailing list for the technically challenged and
cert requests start flying in like crazy, what would you recommend I put for
my users/readers to do in the event a case like this is repeated? Should I
write that they should request another cert? Should I list ag-tech and
instruct them to send an email?
Again, I know the difference between the anon cert and the others, but
consider 48 hours to be a reasonable turn-around time. Thanks in advance
for your help.
--Vic
-----Original Message-----
From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On Behalf
Of Thomas D. Uram
Sent: Wednesday, August 03, 2005 12:50 AM
To: Victor Babson
Cc: ag-tech at mcs.anl.gov
Subject: Re: [AG-TECH] Certificate request
Hey Victor:
I just signed your certificate. If you have any trouble with it, let us
know (ag-info at mcs.anl.gov).
If the certificate request tool doesn't tell you of a problem, you
should be able to safely assume that the request succeeded. Because
these certificates are signed manually, we claim a two-day turnaround on
them (but usually do better than that). If you need a cert in a hurry,
you could optionally request an anonymous cert, which is signed
automatically and available immediately.
Tom
Victor Babson wrote:
> I requested a certificate on Saturday (July 30^th ) at 03:19:13 PM
> Eastern time.
> How can I check to make sure this request was received and I'm not
> checking the status in vain?
> --Vic
