[AG-TECH] Something is wrong with VIC.exe
Natalia Costas Lago
natalia at cesga.es
Wed Apr 27 02:27:41 CDT 2005
try to check the Venue Client log, there u can check how vic is called (the
command line used), and try to call it manually (from a command window).
This way you can check whether there is a mistake on the call (for instance,
if the videostream name has a whitespace in the middle u'll get an error -
at least that happened to me-)
Hope this helps.
Kind regards,
Natalia.
----- Original Message -----
To: <ag-tech at mcs.anl.gov>
Sent: Wednesday, April 27, 2005 4:47 AM
Subject: [AG-TECH] Something is wrong with VIC.exe
> howdy!everybody
> I install the ag2.3. and i want to have a test to check whether the
> client can work well or not . I thought after I fix the camera and connect
> to the venue , I should see myself from the venue .If it succeed ,then it
> can tell me that the client works normally,isn't it? But...After I
> connected to the venue.
> error report comes up :-) It say that: run time error . vic.exe has
> problem.
> i don't know why?
> any thought would be appreciate!!
> zhyuwang
