[AG-TECH] Venue client causing network errors on CISCO 4506
Robert Olson
olson at mcs.anl.gov
Tue Apr 26 15:54:31 CDT 2005
Have you tried a different port on the switch?
On Apr 26, 2005, at 3:50 PM, Michael Gates wrote:
> We've replaced all the accessible cables (machine to wall, switch to
> port), and even the plug plates that the cables plug into in the wall
> and the closet ports. I seriously doubt it's a wall cable, as it never
> moves and there hasn't been any construction on that floor.
> Thanks for the input though!
> -Mike
> Michael Gates
> VTC Services
> mgates at sdsc dot edu
> 858.534.5188
> SDSC Main bld. Room 109
> -----Original Message-----
> From: Robert Olson [mailto:olson at mcs.anl.gov]
> Sent: Tuesday, April 26, 2005 13:41
> To: Michael Gates
> Cc: Lyle Carlson; ag-tech at mcs.anl.gov
> Subject: Re: [AG-TECH] Venue client causing network errors on CISCO
> 4506
> Is it possible you have a flaky cable or connection? We saw something
> like this somewhere, I forget where, where the traffic was triggering
> errors like that and a cable was bad.
> --bob
> On Apr 26, 2005, at 3:23 PM, Michael Gates wrote:
>> I'm wondering if any of the network folks have seen a Venue Client
>> cause
>> errors on a CISCO 4506 Switch with a Supervisor II+ card.
>> Basically, the switch is seeing errors from the host running the
>> software, like this:
>> 5 minute input rate 179000 bits/sec, 54 packets/sec
>> 5 minute output rate 1377000 bits/sec, 333 packets/sec
>> 140735 packets input, 50489999 bytes, 0 no buffer
>> Received 140639 broadcasts (140598 multicast)
>> 795 runts, 0 giants, 0 throttles
>> 2223 input errors, 1428 CRC, 0 frame, 0 overrun, 0 ignored
>> The errors continue to increase with each, what appear to be, bursts
> of
>> packets. If the software is stopped, the errors stop too.
>> Anybody?
>> Thanks in advance for the help
>> Michael Gates
>> VTC Services
>> 858.534.5188
