[AG-TECH] Problem finding new video capture card (Winnov Videum Quattro)
Jason Van Eaton
jasonv at microsoft.com
Tue Apr 26 14:29:29 CDT 2005
Or you can try ConferenceXP - www.conferencexp.net
We only support WDM drivers, and I have personally tested the iTuner
Spectra8 as well as the Winnov Videum.
JVE
-----Original Message-----
From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On
Behalf Of Thomas D. Uram
Sent: Tuesday, April 26, 2005 11:41 AM
To: Natalia Costas Lago
Cc: 'ag-tech at mcs.anl.gov'
Subject: Re: [AG-TECH] Problem finding new video capture card (Winnov
Videum Quattro)
Natalia:
As far as I remember, the iTuner Spectra card already uses wdm drivers,
so it is less well
supported than the winnov card for multiple capture in windows, thereby
further making the
case for wdm support in vic.
Tom
On 04/26/05 13:23, Natalia Costas Lago wrote:
> Thomas,
> I am about to purchase the Winnov Videum? Maybe should I change my
mind
> and buy the Ituner Spectra 8 in order to avoid having trouble with it?
> ----- Original Message ----- From: "Thomas D. Uram"
<turam at mcs.anl.gov>
> To: <cmr at evl.uic.edu>
> Cc: <ag-tech at mcs.anl.gov>
> Sent: Tuesday, April 26, 2005 7:54 PM
> Videum Quattro)
>> There are updates to the VideoProducerService and VideoService on the
>> Windows page for the 2.3 release that have improved support for the
>> Videum card. These attempt to achieve the same effect as Darran's
>> modifications.
>> I suspect the problem you are running into is that the more recent
>> Videum drivers are WDM only. The earlier drivers were VFW-based,
>> which is the type of driver that vic relies on. If you use the vfw
>> drivers, you'll see each input as a selection in vic and in node
>> management.
>> It's unfortunate that Winnov is moving to WDM drivers, but it's
>> entirely expected, since that's the path forward. What the AG
>> community needs is WDM support in vic. I'd encourage anyone in the
>> community with knowledge in this area to look into adding this
>> support; I'm sure that if someone begins the effort, others will jump
>> in and help out to bring robust WDM support to vic.
>> Tom
>> On 04/26/05 11:10, Chris Rosenthal wrote:
>>> I am working on putting together a new hardware configuration for
our
>>> main node and we are testing the new 4 (s-video) input card from
>>> Winnov (Videum Quattro). After receiving some new drivers from
>>> Winnov, I seem to have the card installed properly (I can see video
in
>>> their included software).
>>> However, the card does not show up as an option in the Manage My
Node
>>> dialogue when I try to add a VideoProducer service. I've seen this
>>> problem in the past with multiple Osprey cards, and currently I am
>>> using the edit that Darran Edmundson sent to the list last July (see
>>> below). I could do the same thing, but the card doesn't even show
up
>>> as a device option in vic (so I don't know the name of the resource
to
>>> append to the resource list).
>>> I would really appreciate the help getting this card working as soon
>>> as possible.
>>> Thanks,
>>> Chris
>>> From: Darran Edmundson [mailto:darran.edmundson at anu.edu.au]
>>> Sent: Tuesday, July 06, 2004 1:31 AM
>>> To: ag-tech at mcs.anl.gov
>>> Subject: [AG-TECH] hack to solve Osprey problem under AGtk2.2 and
WinXP
>>> Problem:
>>> For nodes with multiple Osprey cards running AGTk-2.2 under
>>> Windows XP, multiple instances of vic contend for the same
>>> capture card. The workaround is to manually resolve
>>> the vic contentions after changing venues. This is a
>>> pain. Pending a proper fix, you might wish to try the
>>> following. It works for us - your mileage may vary.
>>> Hack:
>>> 1) On your video machine, open the file
c:\Python23\Lib\site-packages\AccessGrid\Platform\win32\Config.py
>>> Save a copy of this file so you can undo the following if
>>> necessary.
>>> 2) Line 985 should be the definition of the SystemConfig class
>>> method GetResources:
>>> def GetResources(self):
>>> Return a list of the resources available on the system
>>> 3) This method builds a list of AGVideoResource entries (one
>>> for each capture device) by scanning your Windows registry.
>>> Our registry did not contain entries for both Osprey cards.
>>> Rather than change the registry, the following hack sets
>>> the list of "found" resources explicitly.
>>> Around line 1020, a return statement sends back the list
>>> of discovered resources. Insert the following code indented
>>> the same amount as the final return statement.
>>> # hack to hardcode known resources
>>> resourceList = list()
>>> resourceList.append( AGVideoResource(
>>> 'video', 'o100vc.dll - Osprey Capture Card
1','producer',
>>> ['external-in']))
2','producer',
>>> ['external-in']))
3','producer',
>>> ['external-in']))
>>> print "hack to hardcode known video resources ..."
>>> return resourceList
>>> 4) Save and restart your video machine AGServiceManager. You
>>> should see the "hack to hardcode .." print statement output.
>>> 5) "Manage my node" and remove and re-add the VideoProducer
services.
>>> You should be prompted for the desired resource.
>>> 6) Let me know if it works ...
>>> Cheers,
>>> Darran.
>>> Darran Edmundson (darran.edmundson at anu.edu.au)
>>> ANU Supercomputer Facility Vizlab
>>> Australian National University, Canberra, ACT 2600
>>> tel: +61 2 6125-0517 fax: +61 2 6125-5088
