[AG-TECH] Problem finding new video capture card (Winnov Videum Quattro)
Natalia Costas Lago
natalia at cesga.es
Tue Apr 26 13:57:03 CDT 2005
But, as I understood, I'll still be in trouble using the AGTK2.3? Maybe I
should buy 4 cards instead a quad one?
----- Original Message -----
To: "Natalia Costas Lago" <natalia at cesga.es>
Cc: <ag-tech at mcs.anl.gov>
Sent: Tuesday, April 26, 2005 8:41 PM
Subject: Re: [AG-TECH] Problem finding new video capture card (Winnov Videum
Quattro)
> Natalia:
> As far as I remember, the iTuner Spectra card already uses wdm drivers, so
> it is less well supported than the winnov card for multiple capture in
> windows, thereby further making the case for wdm support in vic.
> Tom
> On 04/26/05 13:23, Natalia Costas Lago wrote:
>> Thomas,
>> I am about to purchase the Winnov Videum? Maybe should I change my mind
>> and buy the Ituner Spectra 8 in order to avoid having trouble with it?
>> ----- Original Message ----- From: "Thomas D. Uram" <turam at mcs.anl.gov>
>> To: <cmr at evl.uic.edu>
>> Sent: Tuesday, April 26, 2005 7:54 PM
>> Videum Quattro)
>>> There are updates to the VideoProducerService and VideoService on the
>>> Windows page for the 2.3 release that have improved support for the
>>> Videum card. These attempt to achieve the same effect as Darran's
>>> modifications.
>>> I suspect the problem you are running into is that the more recent
>>> Videum drivers are WDM only. The earlier drivers were VFW-based, which
>>> is the type of driver that vic relies on. If you use the vfw drivers,
>>> you'll see each input as a selection in vic and in node management.
>>> It's unfortunate that Winnov is moving to WDM drivers, but it's entirely
>>> expected, since that's the path forward. What the AG community needs is
>>> WDM support in vic. I'd encourage anyone in the community with
>>> knowledge in this area to look into adding this support; I'm sure that
>>> if someone begins the effort, others will jump in and help out to bring
>>> robust WDM support to vic.
>>> Tom
>>> On 04/26/05 11:10, Chris Rosenthal wrote:
>>>> I am working on putting together a new hardware configuration for our
>>>> main node and we are testing the new 4 (s-video) input card from
>>>> Winnov (Videum Quattro). After receiving some new drivers from
>>>> Winnov, I seem to have the card installed properly (I can see video in
>>>> their included software).
>>>> However, the card does not show up as an option in the Manage My Node
>>>> dialogue when I try to add a VideoProducer service. I've seen this
>>>> problem in the past with multiple Osprey cards, and currently I am
>>>> using the edit that Darran Edmundson sent to the list last July (see
>>>> below). I could do the same thing, but the card doesn't even show up
>>>> as a device option in vic (so I don't know the name of the resource to
>>>> append to the resource list).
>>>> I would really appreciate the help getting this card working as soon
>>>> as possible.
>>>> Thanks,
>>>> Chris
>>>> From: Darran Edmundson [mailto:darran.edmundson at anu.edu.au]
>>>> Sent: Tuesday, July 06, 2004 1:31 AM
>>>> To: ag-tech at mcs.anl.gov
>>>> Subject: [AG-TECH] hack to solve Osprey problem under AGtk2.2 and WinXP
>>>> Problem:
>>>> For nodes with multiple Osprey cards running AGTk-2.2 under
>>>> Windows XP, multiple instances of vic contend for the same
>>>> capture card. The workaround is to manually resolve
>>>> the vic contentions after changing venues. This is a
>>>> pain. Pending a proper fix, you might wish to try the
>>>> following. It works for us - your mileage may vary.
>>>> Hack:
>>>> 1) On your video machine, open the file
>>>> c:\Python23\Lib\site-packages\AccessGrid\Platform\win32\Config.py
>>>> Save a copy of this file so you can undo the following if
>>>> necessary.
>>>> 2) Line 985 should be the definition of the SystemConfig class
>>>> method GetResources:
>>>> def GetResources(self):
>>>> Return a list of the resources available on the system
>>>> 3) This method builds a list of AGVideoResource entries (one
>>>> for each capture device) by scanning your Windows registry.
>>>> Our registry did not contain entries for both Osprey cards.
>>>> Rather than change the registry, the following hack sets
>>>> the list of "found" resources explicitly.
>>>> Around line 1020, a return statement sends back the list
>>>> of discovered resources. Insert the following code indented
>>>> the same amount as the final return statement.
>>>> # hack to hardcode known resources
>>>> resourceList = list()
>>>> resourceList.append( AGVideoResource(
>>>> 'video', 'o100vc.dll - Osprey Capture Card 1','producer',
>>>> ['external-in']))
>>>> 'video', 'o100vc.dll - Osprey Capture Card 2','producer',
>>>> ['external-in']))
>>>> 'video', 'o100vc.dll - Osprey Capture Card 3','producer',
>>>> ['external-in']))
>>>> print "hack to hardcode known video resources ..."
>>>> return resourceList
>>>> 4) Save and restart your video machine AGServiceManager. You
>>>> should see the "hack to hardcode .." print statement output.
>>>> 5) "Manage my node" and remove and re-add the VideoProducer services.
>>>> You should be prompted for the desired resource.
>>>> 6) Let me know if it works ...
>>>> Cheers,
>>>> Darran.
>>>> Darran Edmundson (darran.edmundson at anu.edu.au)
>>>> ANU Supercomputer Facility Vizlab
>>>> Australian National University, Canberra, ACT 2600
>>>> tel: +61 2 6125-0517 fax: +61 2 6125-5088
