FW: [AG-TECH] passphrase fails
Thomas D. Uram
turam at mcs.anl.gov
Tue Apr 19 12:36:17 CDT 2005
Steve:
You should have certificates listed in the TrustedCACerts tab of the cert manager. I
suspect there is bad state in your certificate repository. I'd recommend you do the
following:
- Exit any running AG software
- Delete the following directory:
C:\Documents and Settings\<you>\Application Data\AccessGrid\Config\certRepo
- Start the Certificate Manager
- From the requests tab, request a certificate (you could request an anonymous cert, which
will be immediately issued and available)
- When the cert is ready, import it, and proceed as normal
At the end of this, you should have multiple certificates listed on the TrustedCACerts tab
(Access Grid Developers CA, DOEGrids CA, ESnet Root CA, Anonymous). If you don't, or if
there is some other failure, let me know.
Tom Uram
Steve Williams wrote:
> Thanks for those responses:
> Nope, the cert has not expired, it is brand new and the dates on it are
> correct - I even got another one to check that it wasn't just the cert
> and that I hadn't made a typo in the passphrase.
> This is a new install for me - it seems, though I may be wrong, that the
> main problem is that I should have something in the Trusted CA tab of
> the cert manager - I have nothing.
> Does that spark any lights?
> Cheers
> Steve
