[AG-TECH] OSX shared apps
Christoph Willing
willing at itee.uq.edu.au
Fri Apr 8 03:24:40 CDT 2005
On 08/04/2005, at 1:11 AM, Justin Binns wrote:
> I'd guess, from your description, that you're using agpm.py manually
> to install the app packages. What's happening is that the shared
> application database is getting the 'wrong' python interpreter - if
> you do 'which python' on a mac, you get (after resolving soft links)
> /System/Library/Frameworks/Python.framework/Versions/2.3/bin/python,
> which, while it can start a wxPython app, has no access to the UI, so
> the GUI windows will never get focus. If you do 'which pythonw' you
> get (after resolving soft links) a script, which executes a different
> interpreter, namely,
> /System/Library/Frameworks/Python.framework/Versions/2.3/Resources/
> Python.app/Contents/MacOS/Python
> Only the second one (the one you get with 'pythonw') is able to
> actually run python apps with a GUI correctly. The easy solution here
> is to always run agpm.py with pythonw instead of python (except on
> Linux, where there is no such beast). Hope that helps ;-)
Justin,
I was able to replicate the problem using "python", and confirm proper
working with "pythonw". However, when previously running the app
manually, I was using the startup command string as found in the
VenueClient's log file (effectively using "pythonw"); this worked
perfectly. Yet the same startup string when used by the VenueClient
itself caused problems. ???
I rewrote one of the apps in a "nicer" style (less inheritance
trickery) and its working now (on all of OSX, Linux, Windows), so I
guess I'll just have to redo them all.
chris
> Christoph Willing wrote:
>> I'm trying to move some shared apps onto a Powerbook G4 (for AG
>> retreat).
>> These apps work well under Linux and mostly work on the G4 too.
>> However those that employ a gui are a bit strange, in that they don't
>> seem to take focus properly.This means they can't be resized or
>> dragged around the screen with the mouse. Popup menus seem to work on
>> them after a few false starts. If the gui has a menubar, it doesn't
>> appear. MessageDialogs from the gui never take focus either so they
>> never disappear because clicking the OK (Cancel etc) button never
>> works.
>> When these apps are started manually, they're fine and behave exactly
>> as expected. Its just when they're started by joining a shared app
>> instance via the VenueClient's "Application Sessions" node that there
>> is a problem. Its as if the VenueClient is holding onto focus, not
>> allowing its "child" gui's to take it.
>> Has anyone work this out yet?
>> chris
>> Christoph Willing Ph: +61 7 3365 8350
>> QPSF Access Grid Manager
>> University of Queensland
