[AG-TECH] OSX shared apps
Justin Binns
binns at mcs.anl.gov
Thu Apr 7 10:11:31 CDT 2005
I'd guess, from your description, that you're using agpm.py manually to
install the app packages. What's happening is that the shared
application database is getting the 'wrong' python interpreter - if you
do 'which python' on a mac, you get (after resolving soft links)
/System/Library/Frameworks/Python.framework/Versions/2.3/bin/python,
which, while it can start a wxPython app, has no access to the UI, so
the GUI windows will never get focus. If you do 'which pythonw' you get
(after resolving soft links) a script, which executes a different
interpreter, namely,
/System/Library/Frameworks/Python.framework/Versions/2.3/Resources/Python.app/Contents/MacOS/Python
Only the second one (the one you get with 'pythonw') is able to actually
run python apps with a GUI correctly. The easy solution here is to
always run agpm.py with pythonw instead of python (except on Linux,
where there is no such beast). Hope that helps ;-)
Justin Binns
Christoph Willing wrote:
> I'm trying to move some shared apps onto a Powerbook G4 (for AG retreat).
> These apps work well under Linux and mostly work on the G4 too.
> However those that employ a gui are a bit strange, in that they don't
> seem to take focus properly.This means they can't be resized or
> dragged around the screen with the mouse. Popup menus seem to work on
> them after a few false starts. If the gui has a menubar, it doesn't
> appear. MessageDialogs from the gui never take focus either so they
> never disappear because clicking the OK (Cancel etc) button never works.
> When these apps are started manually, they're fine and behave exactly
> as expected. Its just when they're started by joining a shared app
> instance via the VenueClient's "Application Sessions" node that there
> is a problem. Its as if the VenueClient is holding onto focus, not
> allowing its "child" gui's to take it.
> Has anyone work this out yet?
> chris
> Christoph Willing Ph: +61 7 3365 8350
> QPSF Access Grid Manager
> University of Queensland
