[AG-TECH] ToolKit to inSORS
Andrew Rowley
Andrew.Rowley at manchester.ac.uk
Mon Apr 4 04:22:02 CDT 2005
You cannot enter addresses and ports directly. You will either need to have
someone set up the venue of their venue server, or you can run vic and rat
directly. To do this, you can either download them from
http://www-mice.cs.ucl.ac.uk/multimedia/software/ or locate them in your
AGTk 2.3 installation (usually in AudioProducer.zip and VideoConsumer.zip in
C:\Program Files\AGTk-2.3\NodeServices).
You then just run:
rat -t 127 233.2.171.xx/59244
vic -t 127 233.2.171.xx/59246
This will not work if you use unicast/Bridged. In this case, you will need
to have someone set up a bridge for you for this venue and tell you the
address/ports.
Andrew :-)
Access Grid Support Centre,
RSS Group,
Manchester Computing,
Kilburn Building,
University of Manchester,
Oxford Road,
Manchester,
M13 9PL,
UK
Tel: +44(0)161-275 0685
Email: Andrew.Rowley at manchester.ac.uk
_____
From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On Behalf
Of Michael A Gideon
Sent: 01 April 2005 18:45
To: ag-tech at mcs.anl.gov
Subject: [AG-TECH] ToolKit to inSORS
I use inSORS for Access Grid connectivity. I usually connect to other
inSORS sites. I simply select a static venue from a list.
Yesterday, I had to connect to a virtal AG venue and after a lot of
frustration, I found out I had to go to a web site that inSORS hosts and put
in the venue there. At that point I could connect with their software.
So today I want to go just the opposite way. I want to initiate a venue
with inSORS and try to connect to it with AGTk. I called inSORS to see how
this would work. Their tech support told me to get the ip address and the
Audio and Video ports.
So in my example the ip is 233.2.171.xx and the audio port is 59244 video is
59246 ( I think). Now I'm poking around the AG client, but can't find a
place to enter this information. Does anyone have any experience doing
this?
Thanks a bunch,
Mike Gideon
UNR
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20050404/48791f57/attachment.htm>
