[AG-TECH] AG 2.3 on RedHat 9
    Andrew Daviel
    advax at triumf.ca
    Wed Sep 29 18:52:32 CDT 2004
A quick note re. installing AG 2.3 on RedHat 9 (still one of our standard
desktops):
FC1 Packages from http://www.itee.uq.edu.au/~grangenet/ag_fedora/  (thanks
Doug)
  wget -r -nd -np -A rpm \
    http://www.itee.uq.edu.au/~grangenet/ag_fedora/FC1/stable/RPMS/
rpm -Uvh PyXML-0.8.3-1.i386.rpm (upgrade to PyXML-0.8.3-1.i386.rpm from
   FC1 distribution)
rpm -hi *.rpm  (install most 2.3 packages normally)
rpm -hi AccessGrid-2.3-3.i386.rpm --nodeps
 (python-2.2.3 requires libdb-4.1, don't want to go there as sendmail etc.
  use db4)
Use Rat from AG 2.1 or 2.2 (rat-media won't work on RH9 - maybe
     due to Alsa patch)
 - copy /etc/AccessGrid/NodeServices/AudioService.zip from
AccessGrid-2.2-6
  - horrible hack to get 2.2 into tempdir/etc as non-root user :
  rpm -r tempdir -i AccessGrid-2.2-6.i386.rpm --nodeps \
    --relocate=/=tempdir 2>/dev/null
  cp tempdir/etc/AccessGrid/NodeServices/AudioService.zip \
  rm tempdir/*
or just install the 2.2 rpm normally, grab AudioService.zip then upgrade
to 2.3 ...
using this recipe, the venueclient and media seem to work, at any rate
Andrew Daviel, TRIUMF, Canada
Tel. +1 (604) 222-7376
security at triumf.ca
