[AG-TECH] 2.3 & Winnov Videum
Marcus Christie
machrist at cs.indiana.edu
Wed Sep 29 09:46:51 CDT 2004
Fred,
Thanks much! The flickering problem turned out to be an unrelated
issue. I did have to apply the registry edit so that successive
attempts to bring up video bring up the same configuration. But that
was it. Thank you for pointing out the patches, but like you, I don't
need them.
Marc
Fred Dech wrote:
> On Fri, Sep 24, 2004 at 01:04PM, Marcus Christie said:
>>Fred,
>>I've got the same video card here, and I was having a lot of trouble
>>with it. I upgraded to 2.3, but I'm still having some problems,
>>although not as many. In particular, sometimes when I add a
>>VideoProducerService, the video is "jumpy" and after a while it goes to
>>a black screen. It also takes a bit of fiddling to get any video. I
> hi Marcus.
> the flaky stream you describe is something i've not experienced.
> you might want to first check your video cable on both ends and maybe swap
> cables to see if that problem goes away.
>>Any advice you have is most welcome. I also saw in an earlier message
>>something about registry settings. Did you have to do that with 2.3?
> well... i have it from a very reliable *inside* source that 2.3 VIC is
> supposed to handle the registry issues for this card correctly. however,
> when i installed 2.3, i did not get all four streams until i fixed the source
> values for vic.exe[0-3] using regedit. two or three were set to identical
> values. at the same time i modded the source values for WnvConfig.exe[0-3],
> although i suspect that those registry values aren't relevant to AG VIC. i
> also had to modify height and width decimal values in the vic's to match h261
> resolution.
> good luck.
> --fred
