[AG-TECH] Best single machine *Linux* hardware setup
    Osland, CD (Chris)
    C.D.Osland at rl.ac.uk
    Mon Sep 27 10:20:35 CDT 2004
> Is the Rushmore significantly nicer than the G200 MMS?
Anything's nicer than the G200, IMHO!  Good in its day, which was
some years ago.
> What's suitable for video capture?
Looking at our Linux box doing video capture under Linux on a
single processor Athlon XP1600, it took about 8-10% per stream.
So half an XP1600 was enough for 4 streams, using Hauppage
cards.  Haven't used Winnov Videum under Linux, so can't give
you a figure for that.
I'm not a Linux-savvy person, but if Linux can handle multiple
processors intelligently, I would have thought a twin 3 GHz
machine with, say 2 Gb memory, and a decent display card would
be fine.  I don't see that the overall parameters need be much
different for Windows XP and Linux, although the detail may be
as a result of driver availability or performance.
Cheers
Chris
____________________________________________________________________
Chris Osland                         Office tel: +44 (0) 1235 446565
Digital Media and Access Grid      Medialab tel: +44 (0) 1235 446459
BIT Department             Access Grid room tel: +44 (0) 1235 445666
e-mail:   C.D.Osland at rl.ac.uk               Fax: +44 (0) 1235 445597
CCLRC Rutherford Appleton Laboratory (Bldg. R18)
Chilton, DIDCOT, Oxon OX11 0QX, UK
[The contents of this email are confidential and are for the use of
the intended recipient only.  If you are not the intended recipient
do not take any action on it or show it to anyone else,
but return this email to the sender and delete your copy of it.]
> -----Original Message-----
> From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov]On
> Behalf Of John Hodrien
> Sent: 27 September 2004 16:06
> To: ag-tech at mcs.anl.gov
> Subject: RE: [AG-TECH] Best single machine *Linux* hardware setup
> On Mon, 27 Sep 2004, Ivan R. Judson wrote:
> > I'd look at this years Linux Journal Ultimate Linux box,
> here are the specs
> > from www.pogolinux.com:
> > Motherboard/chassis: Celestica A8440 (AMD-8131 Chipset)
> > Memory: 16x PC2700 2048MB ECC REG (32GB)
> > Network interfaces: BCM5704 10/100/1000 x 2
> > RAID: Adaptec ASR2200S
> > Storage: Seagate ST336607LC 36GB U320 SCSI HDD x 4
> > Video: Appian Rushmore Quad-DVI PCI
> > Audio: Creative Labs SB Audigy
> > Power Supply: 500W Hotswap x 3
> > Miscellaneous: PC Floppy drive, IDE DVD-ROM, USB
> > I'm guessing this machine would run either windows or
> linux, and being a
> > quad processor AMD64 it's probably got plenty of cycles.
> Okay, that's one end of the scale.  If I can get the funding eh?
> What's suitable for video capture?  Assuming an AMD64 setup,
> what would be the
> minimum you'd spec for processors?
> As far as an access grid setup, isn't this somewhat over
> beefed.  The disks
> really don't matter a damn if you've got 32G of RAM, and
> you'd never hit all
> that anyway.  Something like 2G a more reasonable amount for
> the AG, such that
> you'll never hit disk under normal operations?
> Anyone looking at
> using twin PCIe cards to get four nicely 3D accelerated outputs?
> jh
> "Computers are useless. They can only give you answers."
>                                                       -- Pablo Picasso
