[AG-TECH] SharedApp on non-venue-client machine?
    Markus Buchhorn
    Markus.Buchhorn at anu.edu.au
    Fri Sep 24 07:33:10 CDT 2004
At 02:03 PM 22/09/2004 +0100, Andrew Rowley wrote:
>One way around this problem is to have a version of AGTK 2.3 running on the
>node that you want to use the shared apps on.  This could be set up to not
>have any services configured [...]If you need to actually run the display machine remotely, you could always use VNC to connect to it.
Indeed, a nice simple solution to start with - thanks! (yeah, ok, ugly as sin too, but it does get us over the first hurdle :-) ).
Cheers,
        Markus
Markus Buchhorn, ANU Internet Futures             |Ph: +61 2 61258810
Markus.Buchhorn at anu.edu.au                        |Fx: +61 2 61259805
The Australian National University, Canberra 0200 |Mob: 0417 281429
