[AG-TECH] Specs for a 2.3 room node
Monika Rabarison
monika.k.rabarison at ccaix.jsums.edu
Thu Sep 23 08:32:15 CDT 2004
It is just that we currently have the old 4 machine node.
I did not know the multiple stream video cards issue is
handled with 2.3 now. In that case, I am thinking about a single machine
running XP. Any specific cards that I should use?
Monika
On Thu, 23 Sep 2004, Osland, CD (Chris) wrote:
> I'm wondering why you want to go for a 3 computer solution? Do you
> want to run different operating systems for different functions.
> As far as I can tell from personal experience and feedback on the
> list, single computer (twin Xeon or twin Athlon, 2.8 GHz or above)
> systems can do everything. It's taken a time to get AG 2.3 support
> for multiple stream video cards into the distribution (the original
> registery fix we circulated in March was for AG 2.1.2), but for
> me the ease of a single machine, single network connection, makes
> a 3 machine solution look like hard work.
> Cheers
> Chris
> ____________________________________________________________________
> Chris Osland Office tel: +44
> (0) 1235 446565
> Digital Media and Access Grid Medialab tel: +44 (0)
> 1235 446459
> BIT Department Access Grid room tel: +44
> (0) 1235 445666
> e-mail: C.D.Osland at rl.ac.uk Fax: +44
> (0) 1235 445597
> CCLRC Rutherford Appleton Laboratory (Bldg. R18)
> Chilton, DIDCOT, Oxon OX11 0QX, UK
> [The contents of this email are confidential and are for the use of the
> intended recipient only.
> If you are not the intended recipient do not take any action on it or show
> it to anyone else,
> but return this email to the sender and delete your copy of it.]
> > -----Original Message-----
> > From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov]On
> > Behalf Of Monika Rabarison
> > Sent: 22 September 2004 18:23
> > To: ag-tech at mcs.anl.gov
> > Subject: [AG-TECH] Specs for a 2.3 room node
> > Hi All,
> > What would be the best hardware specs
> > and OS for building a room node with AGTk 2.3?
> > Let say it will be a 3 machine node (display, video capture,
> > audio capture).
> > Any insight would be most appreciated.
> > Thanks,
> > Monika
