[AG-TECH] Installing AG 2.3 on Gentoo
Jon Johansson
jonj at ualberta.ca
Tue Sep 21 07:44:16 CDT 2004
Hi Ti,
Here is the output that you asked for:
venues root # emerge info
Portage 2.0.50-r9 (default-x86-2004.2, gcc-3.3.3, glibc-2.3.3.20040420-r0,
2.4.26-gentoo-r6)
System uname: 2.4.26-gentoo-r6 i686 Pentium III (Coppermine)
Gentoo Base System version 1.4.16
Autoconf: sys-devel/autoconf-2.59-r3
Automake: sys-devel/automake-1.8.3
ACCEPT_KEYWORDS="x86"
AUTOCLEAN="yes"
CFLAGS="-O2 -mcpu=i686 -fomit-frame-pointer"
CHOST="i386-pc-linux-gnu"
COMPILER="gcc3"
CONFIG_PROTECT="/etc /usr/X11R6/lib/X11/xkb /usr/kde/2/share/config
/usr/kde/3.2/share/config /usr/kde/3/share/config /usr/lib/globus-2.4/etc
/usr/lib/mozilla/defaults/pref /usr/share/config /var/qmail/control"
CONFIG_PROTECT_MASK="/etc/gconf /etc/terminfo /etc/env.d"
CXXFLAGS="-O2 -mcpu=i686 -fomit-frame-pointer"
DISTDIR="/usr/portage/distfiles"
FEATURES="autoaddcvs ccache sandbox"
GENTOO_MIRRORS="http://gentoo.oregonstate.edu
http://distro.ibiblio.org/pub/Linux/distributions/gentoo"
MAKEOPTS="-j2"
PKGDIR="/usr/portage/packages"
PORTAGE_TMPDIR="/var/tmp"
PORTDIR="/usr/portage"
PORTDIR_OVERLAY="/usr/local/portage"
SYNC="rsync://rsync.gentoo.org/gentoo-portage"
USE="X apm arts avi berkdb crypt cups encode foomaticdb gdbm gif gnome gpm gtk
gtk2 imlib jpeg kde libg++ libwww mad mikmod motif mozilla mpeg ncurses nls
oggvorbis opengl oss pam pdflib perl png python qt quicktime readline sdl
slang spell ssl svga tcpd truetype x86 xml2 xmms xv zlib"
and the output from "qpkg -I -i -v > qpkg.out.txt" is attached.
I have a couple of perl packages that have USE flags including -threads
That option doesn't appear anywhere else.
My /etc/make.conf doesn't have a USE list yet, I guess I'm getting
package defaults:
venues root # more /etc/make.conf
# These settings were set by the catalyst build script that automatically
# built this stage
# Please consult /etc/make.conf.example for a more detailed example
CXXFLAGS="${CFLAGS}"
Would adding USE="-threads" and recompiling X be enough?
Thank you,
Jon.
>===== Original Message From Ti Leggett <leggett at mcs.anl.gov> =====
>It looks to me like libX11 wasn't compiled with threads and now you're
>trying to compile with and link with threads. What is the output from
>"emerge info" and it wouldn't hurt to include the output from "qpkg -I
>-i -v" either.
>On Tue, 2004-09-21 at 01:02, Jon Johansson wrote:
>> I'm installing AG 2.3 on Gentoo and I'm having a problem
>> (perhaps more then one?).
>> The packages that still need to go in are:
>> venues portage # emerge --pretend ag-libs/agtk
>> These are the packages that I would merge, in order:
>> Calculating dependencies ...done!
>> [ebuild N ] ag-media/vic-1.1.13
>> [ebuild N ] ag-libs/agtk-2.3
>> When I try to install the vic, the build ends with:
>> collect2: ld returned 1 exit status
>> make: *** [vic] Error 1
>> !!! ERROR: ag-media/vic-1.1.13 failed.
>> !!! Function src_compile, Line 41, Exitcode 2
>> !!! Failed to make rat
>> Calculating dependencies ^H ^H ...done!
>> >>> emerge (1 of 1) ag-media/vic-1.1.13 to /
>> >>> md5 src_uri ;-) ag-media-2.2.tar.gz
>> I've attached the output of the whole build in case it's useful.
>> I'm obviously missing something but I don't know what it could
>> be. Would anyone have a suggestion?
>> Thanks,
>> Jon.
Jon I Johansson * Research Computing Support
jon.johansson at ualberta.ca * Computing and Network Services
Tel.: (780) 492-9304 * University of Alberta
Fax.: (780) 492-1729 * Edmonton, Alberta, CANADA
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20040921/700d81b7/attachment.txt>
