[AG-TECH] Installing AG 2.3 on Gentoo
Jon Johansson
jon.johansson at ualberta.ca
Mon Sep 20 18:02:33 CDT 2004
I'm installing AG 2.3 on Gentoo and I'm having a problem
(perhaps more then one?).
The packages that still need to go in are:
venues portage # emerge --pretend ag-libs/agtk
These are the packages that I would merge, in order:
Calculating dependencies ...done!
[ebuild N ] ag-media/vic-1.1.13
[ebuild N ] ag-libs/agtk-2.3
When I try to install the vic, the build ends with:
collect2: ld returned 1 exit status
make: *** [vic] Error 1
!!! ERROR: ag-media/vic-1.1.13 failed.
!!! Function src_compile, Line 41, Exitcode 2
!!! Failed to make rat
>>> emerge (1 of 1) ag-media/vic-1.1.13 to /
>>> md5 src_uri ;-) ag-media-2.2.tar.gz
I've attached the output of the whole build in case it's useful.
I'm obviously missing something but I don't know what it could
be. Would anyone have a suggestion?
Jon.
Jon I Johansson * Research Computing Support
jon.johansson at ualberta.ca * Computing and Network Services
Tel.: (780) 492-9304 * University of Alberta
Fax.: (780) 492-1729 * Edmonton, Alberta, CANADA
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20040920/4ec63a19/attachment.txt>
